just want to double check these sizes for wheels
It's taken me quite awhile to get around to ordering the wheels (Volk Progressiv ME), but now that I have contacted Mackin, the standard 19x8.5 (+35) and 19.9.5 (+45) are out of stock for a few months or more. I'm not one to wait, especially when they told me I can do a 19x8 (+43) (and use a 5mm spacer) and 19x9.5 (+35), which these they do have, and i've momentarily placed that order. My tire sizes thourgh BFG (a sponsor, yay!) woul dbe 235/35/19 (f) and 265/30/19 (r), ...I tried for the 275 but they discontinued that size, ..which may work out better nayway with the +35 in the rear anyway.
Thoughts?
Greg
Thoughts?
Greg
+45 is what i wanted in the rear, but am having to settle for the +35 w/ a 265/30, ...still think that will be ok?
fronts will use the 5mm spacers on the +43 to bring the offset to +38 (closer to the +35 as I initially wanted)
make sense yet? ..confused? I am.
RAYS specifies certain offsets per wheel width for every car (meaning every cars caliper size).
my volks specification were +34 +40 on 8.5, 9.5. obviously my wheels are different from yours, but rays is an odd company when it comes to wheels. they makes several models per wheel width and their offsets not only change the actual offset but the spoke arc.
if i was you i'd go with what mackin says because its probably what rays says. or you can use spacers. just some info
i was checking around for the right tire and i feel that the 265/35/19 is the closest OD to stock is350s is it correct to use this tire. Stock OD is 26.03 The 265/35 is 26.30.
Napalvr
01-16-15 06:28 PM
CamRen
Wheels, Tires & Brakes Forum
14
10-27-03 11:12 PM
