8000k Hid Problem in is350
Old 06-06-06, 02:38 PM
Sean1692
Sean1692's Avatar
Default 8000k Hid Problem in is350
Hi guys just wondering if anybody has had the same problem i installed a set of 8000k hid bulbs (my car had the 4300k stock) and now when i turn the lights on they stay on for like 30 seconds then just shut off... also my check vsc light came on just wondering if anybody has any input it would be greatly appreciated
thanks!
Old 06-06-06, 02:49 PM
Slowk20a2
Slowk20a2's Avatar
thanks!
does your car have OEM HID or aftermarket plug&play HID kit? If you have OEM HID, you must use D4S bulb.
Old 07-15-06, 02:39 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Did you get your problem fix?
Old 07-15-06, 07:50 AM
C280to250
C280to250's Avatar
He probably just put the original back.
I'm Sure he got the D2s instead of D4s thats why it shuts off.
Old 07-15-06, 09:33 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Wanted to see how the 8000k looks.
Old 07-15-06, 05:28 PM
IS350JY
IS350JY's Avatar
I put the 8000K HID's in my IS350 and i used the D4s with the plug and play and it looks amazing. Everyone that has seen it so far notices it right away and loves how it looks. I will add pictures later.
wpbmed
ES - 5th Gen (2007-2012)
09-09-12 03:20 PM
dexteres33
01-29-10 12:06 AM
four o two
Lighting
12-29-08 06:44 PM
Sean1692
Lighting
06-08-06 11:28 PM
ybing
Lighting
03-30-06 01:08 AM
Quick Reply: 8000k Hid Problem in is350
