WTF hit rev limiter with ECT power on and trac off
I've had a few of my cars do that. It was usually the first time I took it wide open after a new reprogrammed PCM. But I'm guessing the computer had to learn that high RPM shift point.
Stranger things have happened. I have no doubt it happened as you describe. I've had at least two instances where, when switching from D to S, it shifts to 3rd gear instead of 4th as it's supposed to. Both times were while stopped at the light. Both times were also after running the car pretty hard. I think the shift programming does have a few idiosyncracies.
