Vaistech SLI iPOD intergration installed(pics)
#121
Originally Posted by Lex-Luther
Does the pic above dispell the rumor that our headunits do not do CD text with the VAIS???????????????
![](https://www.clublexus.com/gallery/data/3652/medium/IMG_1296.JPG)
edit: so i read the manual a little more and it's still a bit confusing but i'm just wondering if there is something we can do about the delay when changing tracks. it's not bad, just annoying.
#122
Been playing around with mine some more today and I found if you reset your iPod the lag seems to be reduced significantly.
Also, got rid of the NO TITLE issue by going to simple mode and then back out.
Still haven't solved the SCAN volume adjustment issue for non-Navi/non-ML radios - I can't get the unit to adjust its internal volume settings, they are good for my iPod, bad for my AUX XM input.
Edit: the NO TITLE issue still exists, the simple mode "trick" doesn't work reliably.
#123
I had the SLI installed today in the ES350. We attempted to do the nav hack but it disabled the backup camera and the hack didn't work. Since the place was closing, we ran out of time and I have to go back on Wednesday to fix it. Is there anyone that can comfirm the wires for the nav hack are the same as the IS model Nav generation 5?
#124
Originally Posted by kensteele
Just curious about the "mp3" label up near the top. Is that emulation mode? I think for our 2IS, we use CD-MP3 or SAT emulation mode. What about "CD Changer Emulation Mode" or even "MD Changer Emulation Mode?" Just wondering what effect that would have on the operation (slow to change tracks). According to the manual, this programming "must be done in order for the unit to find proper address location in the vehicle audio/video network."
BTW - we ran into a problem doing the nav hack and disabled the backup camera instead. I have to go back to have it fixed. Anyone know anything about this in an ES350 and if the procedure is different than the IS model?
#125
Thanks to all the posters whom have helped to pave the way! I have now completed the install and the Nav Hack and both work fantastic!
I did have trouble finding the iPod harness plug on the radio as to do the Nac Hack 1st, I left the HU upright and could not see the radio plugs hiding under the black shelf of the radio, under the black wireing loom all tied up. All the Nav hack photos do NOT show the bottom of the stack where these plugs live. So, I built up a shelf on the passenger seat with a towel, a board to span the seat without digging into the leather, and finally a foam block and towel, so the brackets could safely dig into something soft. Then pulled out the HU further and laid it on its side. Carefully uncut the bottom loom and there are the plugs! For those who have not yet made the journey, here are three pictures. First is loom uncut, all plugs in, Second (out-of-focus, sorry) is the plug you want, only partially in. Third, is the Vastech Y-cable plugged into the HU and factory harness, BEFORE re-wrapping some of the Y-Cable loom to tidy it up, before reinstall.
http://web.mac.com/stugary/iWeb/Gary...e/Vastech.html
I mounted my unit behind the carpet under the glove box, so I can access it eaiser. When doing so, the earlier post about routing the cables, over and behind the HU bracket is CRITICAL for the ash tray to clear and work. I mounted the iPod in the armrest bin, but behind the cup holder mount, so we still have the cup holder. Again, thanks for the post on how to do that!
I tried MD mode, none of the advanced text screens showed. I then used CD mode, same result. On My ML, the CD-MP3 mode gave me all the text and folder lists, works great!
The "I-agree" bypass screen setting was off as the unit shipped from Vas Tech, so I had to enable this per the manual. All in all, I am thrilled to have a great degree of iPod control, even while driving, plus being able to FINALLY listen to DVD Video music disks when driving!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#126
#127
Originally Posted by VVT-i
I don't think the wire for the nav hack is the same on the ES350. You may need to find out about the wiring from Lexus first, you're a brave man.
BTW - I'm a brave woman. My husband never would have attempted such a thing. Now I have to have the installer undo what he did and hopefully my backup camera will work again. But I'm really pissed that I needed to do this in the first place just to enable a feature (song details) that should be there anyway.
#128
Fire Chief,
The big white plug is what you pull out? Would you describe the steps in slightly more detail?
Thanks
BTW: These steps were always missing (with pictures). Thanks a lot and it's great to find another Mac user!
Thanks
#129
Originally Posted by BShears
Fire Chief,
Thanks
Thanks
#130
^^^i think that's the best way to remove the plugs, i didn't do that....removed just the one plug and it was kinda difficult until i used a tiny screwdriver to pry and leverage. the plugs are unique which is good and again, you have to make sure you push them all the way in tight....without damaging the pins.
on another note, i reset my ipod nano and the lag is still there, resetting didn't help much. and on the "i-agree" screen, you have to wait a few seconds for it to clear automatically else if you put the car in reverse (with rear-camera) too early, it won't work. i keep reaching for the button out of habit, gotta get use to this "cool" feature.
#131
Originally Posted by jewel
On the first step, taking out the two trim pieces, start with the end closest to you and pull it up and back towards you. The clips are U shaped and will come loose when you pull it back.
Did you guys just pull it or did you use a pry tool (like a screw driver)?
"the end closest to you" = the pointy part closest to the back seat?
Mine is in pretty sung. I just got the car 4 days ago.
#132
Simple questions:
#133
I found that video. It looks so easy.
Is it true that you lose the turn-by-turn voice commands when you do the hack?
I understand that you can't get the song details (title, artist, album) to display while in motion if you don't do the hack. I'm not sure it's worth the trade-off since I'm planning on watching the road and not a movie when I'm driving.
#134
By the way, on the dash vent pull, use one credit card to protect the soft lip, then pry between the card and vent with a plastic or taped up pry tool. Works well if the card is over the outer edge clip location, they don't lock down as well.
