Aftermarket Sound System Owners Post Your Setup!
Old 05-17-07, 09:24 PM
  #151
jmlaudio
jmlaudio's Avatar
This is a sound quality set up. There are a set of hand made in Denmark Dynaudio components and zapco amplifiers. As far as the balanced goes that balances happens through a tranmitter after the OEM gateway. The 4080 box is designed by Ainsley I trained under his brother mark a number of years ago.
Old 05-17-07, 09:38 PM
  #152
kilo6_one
kilo6_one's Avatar
Im old school, i like MBquart and some zapco or arc audio amplifiers, you cannot go wrong.
Old 05-18-07, 06:51 AM
  #153
mark5
mark5's Avatar
Originally Posted by vApor21
same. i actually asked him like a year ago if he would do it for us, but i never got to talk back to him cuz non-cl vendor GBs arent allowed here..
I bought a box from him, great box. is he considered a vendor?
Old 05-18-07, 07:24 AM
  #154
iSuxeL
iSuxeL's Avatar
MB Quart!
Old 05-18-07, 07:30 AM
  #155
Technique
Technique's Avatar
Orion is my personal choice...
Old 05-21-07, 02:30 AM
  #156
s0l0
s0l0's Avatar
Default confused, need a little clearification
Originally Posted by cmusic
Maybe you could use one NE-774V and run the sub and woofer inputs to it to get a signal up to 1 KHz to the amp.
Now I'm a little here. After you running one channel (Front Left Woofer) and the other channel (subwoofer) through the NE-774V, how do you connect the two reduced voltage RCA's to the aftermarket amplifier to get a summed signal? Will the amp be doing the summing? Or does the NE-774V do the summing? Or is there any summing at all or is it just reducing the voltage to be 0v-9.5v? I have a Rockford Fosgate P550.2 Amp, which doesn't accept high level inputs. I have a two channel LOC and I'm currently using the subwoofer's (+) and (-) and connect it parallel going into the LOC's Left and Right inputs. At the RCA end, I just connect it like normal to the amp's RCA Right and Left Channel inputs. This means I have the same signal going into both channels. Currently, it feels like it's missing some of the bass I used to have when I had my system in my '95 Prelude. I know I would have to sum the signals up somehow to get that missing bass, but don't want to spend over $100.
Btw, here is what I have:
-(2) JL 12W3V3 single voice coil 2-ohms each. I have them in series mounted inside a sealed box and using the bridged outputs of the amp.
-Rockford Fosgate P550.2 Amp
-NAV
-ML
-Stock Head Unit
Originally Posted by Wahmba
Hi C,
Thanks for the info! I did exactly what you suggested (use woofer and sub outputs of the stock amp) and the result is great! I really appreciate your input. The next thing to do is add 2 mid-bass drivers somewhere in the front of the car to give it a little better low-end imaging. Overall, the sound is pretty good for a stock system. Thanks again!
Can you tell me exactly where you tapped into to get your signals for the woofer? Did you tear the door apart to get the wires, or did you get them from the output of the factory amp? Will this combination of summing get you a single signal around (30hz to 400hz) to supply to the amp? Or is it just some settings on the amp that I'm doing wrong?
Thanks for the helpful ideas everyone has provided on this thread.
Old 06-14-07, 12:08 AM
  #157
peterAP2
peterAP2's Avatar
has any 350 owner added a sub to ML?
Old 06-14-07, 05:57 AM
  #158
Technique
Technique's Avatar
Yes, a few of us have...
Here's the thread for my install:
https://www.clublexus.com/forums/sho...d.php?t=255511
Old 06-20-07, 10:16 PM
  #159
effusion
effusion's Avatar
Gotta fix the amp racks...
Old 06-21-07, 11:33 AM
  #160
IS_NIICE
IS_NIICE's Avatar
(2) Rockford Fosgate 12" 400RMS 800MAX
(1) 4 channel RF amp 1500 watts.
Old 06-30-07, 10:42 AM
  #161
effusion
effusion's Avatar
anyone else get a new system?
Old 06-30-07, 11:23 AM
  #162
VF84
VF84's Avatar
Originally Posted by jmlaudio
...a set of hand made in Denmark Dynaudio components...
nice, volvo uses them as upgraded factory units. i'm runn'n dls in my wagon..
Old 07-20-07, 03:39 PM
  #163
Julez
Julez's Avatar
My set up is pressurized and I'm too scared to open it up and tear the material, here are my stealth pics, I wanted trunk space
Alpine Type X 12” subwoofer and V12 1000 watt Class D amplifier
If I take it off ever I will take a pic
Old 07-20-07, 09:13 PM
  #164
Blk_An_Tan
Blk_An_Tan's Avatar
Originally Posted by is_elf
Wow, all the systems posted to the site look really hot. Almost makes me not want to post mine. But I like mine and it sounds good, let me know what you all think of it.
I am running 2 Memphis 15-M1104D their power source is a Memphis 16-MCD1000D, in the doors I have Eclipse SC8365 run off a Memphis 16-MCA5004.
Did you make these your self? How many cuft are they? I want to put JL 10w3v3 in my trunk and they need about .625cuft each.
If you didnt make them yourself, where can you buy them at?
Old 09-24-07, 08:19 PM
  #165
Fearlessfx
Fearlessfx's Avatar
Originally Posted by tuandang79
thats right Pro... I hope you enjoy your stereo!.. here is the finish part
this set up is awesome, i am seriously considering adding a head unit like that to my IS, however i have questions as to how it would work.
is it somehow tied into the stock lexus sound system? or does it replace the system entirely? in canada the nav screen isnt an option on the IS250 so i want to add an aftermarket touchscreen/nav/deck.
Quick Reply: Aftermarket Sound System Owners Post Your Setup!
