Nice! Interesting choice with two single DIN units. On the wiring side, did you tap wires and bypass the factory amp, our use an aftermarket integration unit for the factory amp?
I basically ran all new wires in my front doors. my rear doors.
I removed the ML amp and only use the stock harness to power the cd changer that is behind my
alpine pxa h700.
my dvd player and eq are powered with wires I ran to the main fuse panel.
if you remove the circuit board from the cd changer and build a box to put it in. power itup and the a/c and display will work again. find my build thread its explained in there.
Beat sonic is almost done with there kit. they aready have the wiring interfaces to retain the factory amp ML or non ML.
Can anyone supply the wire diagram on the stock amp for a 2007 IS250 without the MS system. I need to know which wire to tap into for my amps, or which ones to use for the input into a MS-8 or Helix DSP?
Also, is there any pair of wires that are a full range signal, or will I have to use for example, the sub channel output along with others to get a full range signal?
I really want to get this so I can use the pioneer 80prs single din head unit. I'll be calling BS tomorrow to get some more info.
I just want an easy "plug and play" because if I run into problems, i'm not tech savvy to troubleshoot.
I wanna see this setup. It's what I'm considering.
I have an 08 GS450h with Nav and cassette player as well as the Mark Levinson sound system. The bottom (radio) I believe is separate from the nav and a/c controls. I took it all out to replace my upper vents when some idiots broke it cleaning the car and it all came out as a complete unit. I'm wondering if the unit separates...
Anyway...I wanna see this setup please. Pix!!!
Originally Posted by IS4U2NV
System:
1 JL 13W7 in sealed enclosure / 1 JL 1000/1 Amp / 1 Lightning Audio 1 Farad Cap / David Navone LOC / JL CL-RLC Line attenuator (remote bass ****) / Interior is the 14 speaker Mark Levinson 7.1 surround sound system
Paint finish is the same as the exterior as the car (Smoky Granite Mica) And the grills are not because it's a ported box, they channel the sound from the trunk back in to the vehicle.
Here is a pic of my old setup for ref:
And on with the new under construction, and finished:
