Aftermarket Sound System Owners Post Your Setup!
#62
I don't think JL allows authorized dealers to sell online. Of course you can probably find it online somewhere, but JL will not honor the warranty. I'd say you can't go wrong with Crutchfield online. Not the best prices, but reputable and they have tons of good information and excellent customer service. Lots of other sites out there, but your mileage may vary with them.
#63
10" JL Subs
12" JL Subs
JL Amps
Word of warning: They took FOREVER (10 days after payment) to ship my order, but most people don't seem to have problems, so YMMV. They also sell on eBay and have decent feedback (except from me). Nonetheless, their prices are right, and they did ship the product eventually.. I'd do business again.
#64
Factory CD indash changer moved to the glovebox
Head unit: Alpine F#1 Status CDA-7990
Sound processor: Alpine F#1 Status PXA-H900
Amplifier #1: Alpine MRV-F545 (front doors and sub)
Amplifier #2: Alpine 30x2 (center channel)
Front door speakers: Boston Acoustics Z6 6.5”mid and tweeter
Center Channel: Tang-Band W3-315 3” full range mid
Subwoofer: Alpine Type-X SWX-1042D 10” sub
Wiring and electrical accessories: Stinger
Future upgrades:
Finish trim around head unit
Add Brax X2400 amp to bi-amp Z6 speakers
Redo trunk installation
Add rear door component speakers for full 5.1 setup
Add Alpine DHA-S680 6-disk DVD changer
Upgrade battery
Future upgrades:
Upgrade battery
If i want to install a sub, are these the accessories that i need?
Stinger Amp Kit Includes:
18 ft. - 4 Gauge Red Custom Pro Power Wire
3 ft. - 4 Gauge Black Custom Pro Ground Wire
17 ft. - 18 Gauge Blue Remote Turn-On Wire
1 – 24kt Gold Plated ANL Fuseholder with Mounting Screws
1 - 150 Amp ANL Fuse
1 - Custom Pro 4 Gauge Ground Lug
Assorted Ring Terminals, Spade Lugs, Butt Connectors, and a Plastic Grommet
7" Black Wire Ties """"
and
Stinger Expert Series SX17 Interconnect Signal Cable i.e RCA connects?
Please let me know what else i need for my setup.
Thanks
#65
Hey CMUSIC,
and
Thanks
and
Thanks
Everything else you listed looks good.
#66
You also need a speaker to RCA line output convertor (LOC) if the amp you are using does not have speaker level inputs. I like David Navone products. The NE-7V would work well in the IS's audio system. http://www.davidnavone.com/adaptor_products.htm
#67
What is an SLI?
I had an 8W7 and blew it with a 600 watt amp. So be careful with that 1000 watt amp powering the 8W7.
#68
The RF amp you have does not have speaker level inputs. It has RCA inputs and can only handle probably up to 8 or 9 volts of audio signal. The factory amp speaker outputs carry 20-25 volts to the speaker. The LOC lowers the voltage down to a level so the RCA inputs won't be damaged by too much voltage.
What is an SLI?
What is an SLI?
#69
Both the 500/1 and 250/1 can accept speaker level inputs. You flip a switch on the amp near the RCA inputs and then plug in a pair of RCA cables that have been connected to the factory amp's sub wires. BTW, on their website JL Audio recommends the 250/1 to be used with a single 8W7.
And yes, I can re-install the factory sub as it came from the factory. It just bolts in place and the wiring plugs into it.
#72
is it worth it to get the ML package if you're thinking about getting a sub or 2 installed?
#73
#75
hehe, is there an echo in here??? Look a few posts up, from a few days ago, I already posted that those look like W3's, even though the OP never responded... His sig is obviously incorrect...
