How would you get sub 5 second 0-60?
Old 12-19-06, 09:19 PM
  #31
LexFather
Guest
Posts: n/a
Thumbs up
Originally Posted by mvalpreda
I'm taking a bit of poll.....how would you modify your IS to get sub 5 second 0-60 times?
It won't take much to be honest.
1. Cold air. Run her in sub 60 temperature
2. Top high performance tires for street. Semi-slicks if your really serious. Keep the tires WARM for best grip for the best start
3. Delete spare, no NAV, no sunroof, no carpet, get rid of sound deadening.
4. Lower fluids, keep 1/4 mile of gas in the tank
5. BBK, 2 piece brakes weight less than stock brakes
6. Lightweight 17" wheels.
No stickers
Old 12-19-06, 10:58 PM
  #32
combfilter
combfilter's Avatar
Originally Posted by CWS
Just find a 1/4 run that's down a steep hill. That'll work.
HAHAH lol
Old 12-20-06, 01:25 AM
  #33
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,982 Likes on 2,410 Posts
Originally Posted by Irishman06
survey says:
(bzzzz) Oooo, soo sorry. Lighter, in a race car, is better, because it allows you to control WHERE you want the weight you DO have.
By locating the majority of the downward force* of the vehicle as closely together as possible (towards the middle of the car, where the big heavy things like engines and drivers sit), you can lower the rotational inertia of the car, which gives you the handling properties of the cars you mentioned.
Using the suspension, you can control then where that downward force interacts with the ground: cornering forces and downward forces are DIRECTLY proportional, in general: more weight on the tire = higher normal force = higher friction force. The more you push down with your hand on a table, for example, the harder it is to slide your hand across the table.
I put a * next to downward force, because weight isn't always the only component, on high end racecars (and even high end sports cars these days), you actually have aerodynamic downforce being generated "pushing" the car onto the road. Why would engineers go through so much effort to add what is essentially weight to a car?
I've driven a car that had too little weight: a Formula SAE car. With driver, it weighed under 650 lbs, and made almost 85 horsepower at the wheels. If you ever put even the slightest bit too much throttle into it (on extra-soft race slicks, no less), you'd light those suckers faster than a chain smoker could light his next cancer stick. I don't think its a very big coincidence that the biggest drivers at FSAE schools are typically the fastest: they've inherently got an extra 50-60 lbs of normal force to work with, and sometimes more.
You're missing the concept here. Designers use aerodynamics to effectively increase weight without increasing mass. That's the whole point. Analyse the vectors and you will see a car with 2000 lbs weight + 500 lbs downforce will out corner a car with 2500 lbs weight and 0 downforce every time. Lighter is always better. Just because it is hard to drive doesn't mean it isn't faster. Look at any Formula/CART/IRL car and figure out just how much throttle you need to light up some very impressively grippy slicks.
And being able to position the weight only applies when their is a minimum weight. If there's no minimum weight, you can bet the car will be made of the most exotic materials in the most Chapmanesque way possible. Colin knew it too - lighter is always better.
Old 12-20-06, 02:16 AM
  #34
bobbo1978
bobbo1978's Avatar
You forgot the point that people want to be unique.
Originally Posted by Bichon
The whole point of the IS350 is to blend performance and luxury. If an owner is willing to strip out most of the luxury in the quest for more performance, me thinks he bought the wrong car. There are any number of cars, e.g., WRX STI, EVO, that are quick, less expensive, and cheaper to modify.
Old 12-20-06, 07:39 AM
  #35
Koz
Koz's Avatar
Power to weight and how efficient you get the power to the ground. This is why motorcycles run 0 to 60 in sub 3 sec.
Koz
Old 12-20-06, 08:01 AM
  #36
NovaIS350
NovaIS350's Avatar
Do you guys think it's possible to hit 5.0 flat 0-60 sprint, whilst retaining all the luxurious amenities and no forced induction?
Old 12-20-06, 08:24 AM
  #37
Irishfan
Irishfan's Avatar
I would think so. Little gas in the tank, R-compound tires, cold day, exhaust a la LMS, I bet you'd hit sub-5 seconds fairly easily. I could be wrong, though, looking at Caymandive's numbers. I think the cold, dry weather would be the biggest help.
Old 12-20-06, 09:22 AM
  #38
Larry96815
Larry96815's Avatar
The first day it hits 55' here I am giong to try all this.
Aloha
Old 12-20-06, 11:01 AM
  #39
tt061880
tt061880's Avatar
my car runs 13.5 1/4 mile, how fast would that be 0-60?
Old 12-20-06, 11:05 AM
  #40
NovaIS350
NovaIS350's Avatar
I'll take a good guess, 5.2
Old 12-20-06, 11:08 AM
  #41
tt061880
tt061880's Avatar
I think it should be faster than that, Lexus advertised the IS350 14.2 1/4mile and 5.3 0-60.
Old 12-20-06, 11:14 AM
  #42
caymandive
11 Second Club
caymandive's Avatar
It's very hard to guess at what your 0-60mph is. Too many variables involved. For exampe: an EVO IX can run a 13.3 stock quarter mile and get mid to high 4's for 0-60. Gearing, traction off the line, etc.
Old 12-20-06, 11:17 AM
  #43
NovaIS350
NovaIS350's Avatar
14.2? wow...from what I've seen on dragtimes.com & CL it seems like you would have to try hard to get a 14.2. 13.6-8 is the norm.
Old 12-20-06, 11:25 AM
  #44
GSteg
GSteg's Avatar
I have to agree with you on this. Less weigh is better. Heavier car tends to swing out easier. Newton's law comes into play. More mass is going to lead to a higher radial acceleration in which the car has to fight in order to stay on track.
Now if your car is able to swing out easily on a light weight car, then either you do not have enough downforce, or your tires must not traction.
Old 12-20-06, 11:39 AM
  #45
cspec
cspec's Avatar
There's a Japanese video of the IS350, doing 0-60 in 4.54 seconds... stock.
Quick Reply: How would you get sub 5 second 0-60?
