Taking The Mystery Out of Fog Light Bulb DIY
#151
Can you change color of lightbulb after doing HID conversion? is it basically the same lightbulb you use for ur headlight, but through a HID kit, that same lightbulb is brighter? am i on the right tracK?
#152
I'd do a search for the Kelvin table and also see more pics of what others have had done to determine what you want. Check out the lighting forums on this site too. Lots of info there.
#153
#157
I was just messing around with fog lamp bulbs this weekend. For the 2009 awd, you have to take the wheel well cover slightly off, not all the way off for both sides. Very easy to do, like 10 min per side. It was like 2 clips and a screw.
#158
Here's mine Luminics Krypton JDM Yellow 9006
On the right New Yellow bulb, kind of hard to see, but still...
#159
need some help... i can't seem to find this access cover on the driver side, all i say is the same pins on the passenger side as the driver side.
i have a 06 is350 if that matters,
any help is appreciated!
#160
Also, for everyone who has done this before, how much were you able to pull the liner out? I had no problem taking out the initial stuff but it seemed like the liner on both sides seemed especially stubborn. I put everything back because I couldn't open the hole up large enough to even see the fog light connector
#162
I also do not have the access cover on the drivers side. My car is an '08 IS 250 AWD
