Taking The Mystery Out of Fog Light Bulb DIY
Old 08-07-06, 08:10 PM
  #46
tbs2
tbs2's Avatar
I am glad you told me that. I am gonna change my mind not to change another color for my fog lights.
Old 08-07-06, 11:24 PM
  #47
ULTiMaX99
ULTiMaX99's Avatar
it's really NOT that difficult to change out the fog lights. i went in thru the fender well on both the driver and passenger sides. i even managed to install hid's w/o having to remove the bumper.
Old 08-08-06, 02:10 PM
  #48
TAMR_GUS98
TAMR_GUS98's Avatar
Lightbulb Not Difficult At All!!!!
Yeah, should be able to replace the bulbs on both sides within a half hour tops. No need to go through the fender well on the drivers side when there is an access hole underneath.
-Will
Old 08-26-06, 08:01 AM
  #49
cali_guy
cali_guy's Avatar
i am thinking about performing the hid foglight and was wondering where you installed the ballasts for the hid's?
Old 12-05-06, 02:34 PM
  #50
lexuspdx
lexuspdx's Avatar
Just in case inquiring minds want to know. This is the bulb I had in it. It was nice and "HID like", with a blue tinge. But it was not bright enough IMHO.
This is the yellow I put in it. (No, the blue bulbs you see in this pic, in the packaging is not the yellow bulbs just the packaging for the yellow bulbs)
Can somebody tell me where I can purchase these bulbs and how much they will cost? I just installed aerotect yellow fog overlays. They don't seem to be bright enough. Will these make them brighter?
Old 12-06-06, 01:05 AM
  #51
TAMR_GUS98
TAMR_GUS98's Avatar
lexuspdx,
Try http://www.365motorwerks.com/index.a...arch=GO&Page=1
They were at one of the meets, I think it was BOS. I ended up getting my Luminics JDM yellow bulbs from them. They even told me that they ran these bulbs in their headlights. They said it was legal to have yellow headlights. So, if their bright enough for headlights, then they should be bright enough for fogs. They worked out fine on the wifies car. See the pics in my DIY sticky.
Good luck,
-Will
Btw, I paid $25 for the bulbs. It shipped pretty fast too.
Old 12-06-06, 05:29 PM
  #52
lexuspdx
lexuspdx's Avatar
Originally Posted by TAMR_GUS98
lexuspdx,
Try www.365motorwerks.com
Good luck,
-Will
Thanks! I will go to the site.
Old 12-06-06, 05:35 PM
  #53
TAMR_GUS98
TAMR_GUS98's Avatar
Default Luminics JDM Yellow.
Let me know how everything works out. Post a pic or two on this thread too, after you get 'em in.
-Will
Old 12-16-06, 11:13 PM
  #54
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Good stuff !
Old 12-25-06, 11:37 PM
  #55
zardoth
zardoth's Avatar
Default PIAA Plasma Ion Yellow
I wanted to get the PIAA Plasma Ion Yellow bulbs for my fogs, but was told the tabs on the side of the bulb (the ones used to lock/unlock the bulb into place) are a little too small
http://www.autobarn.net/piaionyellowhb.html
Anyone successfully install these?
Old 12-26-06, 12:15 AM
  #56
DonJuan45i
DonJuan45i's Avatar
why didnt they make an access hole on the passenger side as well?????
Old 12-26-06, 01:01 AM
  #57
TAMR_GUS98
TAMR_GUS98's Avatar
Originally Posted by flyfl1pguy
Good stuff !
Thanks, glad I could help.
The picture in the link you provided is a 194 wedge bulb, but the discription say they are 9005/9006. Not sure about the fitment of the PIAA 9006. I guess the only way to find out is to order them. Or you could just order the Luminics JDM yellow like I have on my wifes car. At $29, it would be alot cheaper than the $89 for the PIAA. Here is the link if your interested. http://www.365motorwerks.com/index.a...PROD&ProdID=85
Was wondering the same but could not find an answer. It would have made it alot easier, huh?
Old 12-29-06, 07:20 AM
  #58
GoHuskers
GoHuskers's Avatar
lexuspdx,
Is $25 for one single bulbs or does it have 1-pair (2 bulbs)?
Do you know how long (bulb's life) will the bulbs last?
Thanks
Old 12-29-06, 11:30 PM
  #59
TAMR_GUS98
TAMR_GUS98's Avatar
Thanks
That would be for the pair. Can't tell you how long the bulbs will last. But as long as you don't touch the glass while installing it, it should have pretty much the same life span of any automotive halogen bulb.
-Will
Old 12-31-06, 09:21 AM
  #60
jurutera
jurutera's Avatar
Default Hot
i got the Phillips bulbs and it has arating of 60Watts on it. It works fine but the bulb is hot from the moment its switched on. I nearly bunrt my finger just touching the fogligt casing. Isthis rating too high and will it damage the foglight?There is the MTEC bulbs which goes on 55Watts and is way cheaper, shud i use that?
Thanks
Quick Reply: Taking The Mystery Out of Fog Light Bulb DIY
