Taking The Mystery Out of Fog Light Bulb DIY
#106
Hey those of you with stock fog lights... I just installed the Luminics 9006 12V 55W->130W 5150K Ultra White bulbs and they are really hot after about 5 minutes. So hot that I can NOT touch the outer fog light lense (the clear plastic facing forward). Is that normal even on the stock fog lights? Someone try it for me. Leave them on for 5-10 minutes and tell me if they are too hot to touch.
UPDATE: Yea the stock ones are just as hot. I put one side back in and they are way hot to the touch too. I guess the plastic housing is made to handle that sort of heat.
Also I have attached a pic from after the install. Camera does not give the most accurate colors, but its an idea. I like the way it looks a lot. Might not do the rvinyl light blue overlays after all.
#109
Takes like 15-20 minutes tops!
For left side (driver side) you should go through the fender lining...it makes it way much easier instead of going through that small hole! All you have to do is remove the 2 clips and if you really want to play it safe, remove the lower clip that secures the lip & fender lining...
Went with the Nokya Artic Whites...was running yellow, but everyone seems to be doing it! No offense to the 1st gens, but needed to go with something different for the 2nd gens!
#111
? on wattage...
Yes...100 W is too high, so make sure when you purchase those you pick up 2 Stage 2 high wattage capacity wiring harness...so you don't fry your stock harness! I'm running 7000k 80W Artic Whites...
#112
I just bought some Nokya 2500k 70W and see if the wattage was ok.
#116
not if you are confident you are not going to touch the bulbs
i just did mine. couldn't find the access hatch so i went through both fender liners. i was about to give up but i couldn't justify actually taking my car somewhere to install light bulbs. i used the luminics yellow bulbs and it looks really good,
#118
Gloves are not necessary. Try it out for yourself but have the gloves ready just in case. It's personal preferrence.
Glad my DIY helped a lot of peeps!
#120
I just installed the Silverstar Ultras in fogs, the color is definitely whiter than stock, but not white enough to match 8000k HID's, I might just tone the HID's to like, 6000k or so. They should be a nice match though to stock HID's.
Update:
Just checked out how the new fogs look at night. They aren't a match to the 8000k, but definitely looks better than the stock Sylvania bulbs.
Update:
