TPMS problems
TPMS problems
I just had installed g-games 99b into my tungsten pearl IS 350 and have replaced the sensors to the new wheels and initialized it. But after few miles the check system came on. Is there any way to de-activate the TPMS so I wont have to see that annoying check system light. I wonder if the sensor was damage during re-install. This TPMS is so unnecessary and waste of time. Can someone help me address my problem. thanks.
Originally Posted by TimboIS
That's a short sighted assesment. TPMS a great addition to any vehicle.
Super Moderator
I disagree with you that TPMS is unecessary and a waste of time. Performance tires, with their low profile and stiff sidewalls, can be dangerously low on air without looking flat.
I don't particularly like the TPMS in the IS. I prefer ones that give you a digital readout of the actual air pressure in each tire. But the one we have is better than nothing.
To address your needs, I agree that until such time that a pressure monitoring system becomes a federal requirement on new cars, Lexus should provide a mechanism for disabling the system. If they want to keep the lawyers happy, I wouldn't object to a "Warning: Tire pressure monitoring system disabled" warning appearing briefly in the trip computer display each time the car is started.
Had I ignored the light a bit longer I could have ruined the tire, or worse, had an accident. I’m sold on the TPMS concept.
Super Moderator
So, what is the solution to this problem. As you know, many enthusiast enjoys modification of their wheels and tires. Do they just accept it and that many wheels are not compatible to TPMS. In other vehicles does not require sensors on the wheels.
You said you might of damaged the sensors during re-install so this might of been a self-induced problem in the first place. It sounds like you want to completely "disable" the TPMS so just put all 4 sensors on the spare or a wheel barrow tire in your trunk.
Cheers,
Kermee
Originally Posted by conekiller
and soon to be required of all vehicles (thank Ford and Firestone for that)
I still contend that Firestone was not at fault, yet took the bulk of the blame thanks to Ford's passing of the buck. Ford should be ashamed of themselves.
I love to know when tire pressure is low on my IS. I just don’t like the fact that they are expensive units which can’t give us the exact pressure.
In that case I like the system in the 06 BMW 3 series. No sensors inside the wheels. The system verifies the rotational difference between the wheels and alerts you. If I’m not mistaking this is done with the existing ABS sensors. No extra sensors to ad to the cost. Also, I believe it is compatible with any aftermarket wheels!
Originally Posted by Kermee
I follow the sentiments of everyone else who's replied so far and no one has seem to have changed your mind.
Cheers,
Kermee
Cheers,
Kermee
-Brian
Super Moderator
Originally Posted by rys
As I posted in a different thread, it MAY be possible to disable TPMS by disconnecting the control computer. The black box at the very top of the radio stack should be the TPMS controller.
-Brian
-Brian
Yes and no, my speculation is that they located the TPMS ECU at the top of the radio cluster so that it could be disconnected. The other ECUs are not conveniently located (SRS, ABS, etc).
-Brian
-Brian
Liquid Bra Champion
