Badge Removal Question
Ok, so I was looking at pics of other ISx50s with the badges removed, and I decided that I prefer the way it looks. I was looking at my badges, and they are just stuck on with black rubber tape crap. Will I peel the paint if I try to pull them off? Can anyone recommend anything to use to take it off without fuxxoring up the paint?
Thanks.
Thanks.
1st off, there are holes in the trunk that help secure them on. If you take off the badges, you would have to fill in the holes and have it repainted.
2nd, if you decide to do it, just get a hairdryer and some fishing string, use the heat to loosen up the tape, and the string to peel away the emblem
Thanks.
Thanks.
good luck
https://www.clublexus.com/forums/sho...2&page=1&pp=15
Originally Posted by uschardcor
here's how your de-badge your 2IS
load the clip
release the saftey
eye-check the barrell and finger-check the trigger at the same time
load the clip
release the saftey
Seriously Your a Moron. I've been Reading your Past post you provide Absolutely no HELP Whatsoever.Comments on thread Providing your expertise that you know nothing of.
Why do you post? This Forum Should be helping Each other with Question not your Stupid Comments. Its a watse of my time to click on the Thread thinking there would be a solution and your Dumb name comes up with post like this!
I got an idea... Why don't you Put a Shot gun Barrell into your mouth ( you probably like shoving stuff in you mouth anyway) and then pull the trigger.
the_ez_rhino
Automotive Care & Detailing
07-26-04 10:52 AM
