Am I the only one having problems?
My IS350 is one month old, 3k mi. Silver with sports package.
My biggest problem is the ride. My passengers and I have found the ride to be very bumpy and rough. I used to have a 99 Accord, and I feel like that ride was smoother. Am I expecting too much? Is it the sports package suspension?
Problem #2: When I drive with the sunshade open on the street, I can hear the sunroof window squeek every time.
Problem #3: I've already had paint chipped off my front bumper (about a one centimeter), probably from a rock on the highway. Should this have happened so easily?
I appreciate the feedback .
The paint issue is common with all modern cars. Compliance with recent laws requires use of softer paint...I suggest buying some touch up paint and not tailgating...not much else you can do other than a clear flim over the front.
Re: the ride...did you test drive the car before purchasing? This car has 18" wheels with low profile tires to begin with, and you opted for the sports package which has SPORT TUNED SUSPENSION. That means it corners better, but rides rougher. Consider trading your wheels with someone w/17 inch wheels from an IS250...I think you'll easily find willing candidates, and that should improve your ride quality. In any case, if you're very concerned with a smooth ride, do not buy a sport suspension upgrade next time!
Originally Posted by meteoro
The paint on all new Lexus' is very soft, it does not contain lead, its environmentally friendly. Best bet is to get a clear bra.
Cycle Savant
Super Moderator
Originally Posted by PhilipMSPT
Also check your tire pressure. It should be a few psi lower than the max psi. Overinflated tires will make it a more bumpy ride...
My 18's were at 42 psi from the dealer
I dropped them all to 34 psi and the ride changed considerably for the better, however I wasn't unhappy with it to begin with. Never, and I mean never, inflate your tires to what the tire sidewall says, go by your owners manual.
Sorry to hear you're unhappy with your car but I agree that when you got the sports pkg, you should expect the ride to be a bit firmer/more taut than a non-sport pkgd car. To me, the car rides great. Much, much better compared to my '03 Accord. Totally smooth and not bumpy at all.
As for squeaks and rattles, there're a few when the temp is really hot (as how it's been here in So Cal) but I think it's just the plastic comforming under intense heat.
https://www.clublexus.com/forums/sho...d.php?t=214573
view my post #2. This needs to be done every so often. It works though!
This car doesn't handle freeway expansion joints that well. I have a IS350 with Luxury Package and it feels like a truck over expansion joints. I came from a BMW 330CI with Sports Package and the suspension on the BMW handle expansion joints much better.
LexFather
11-02-08 08:45 PM
