NAV Hack Side Effect?
#31
Originally Posted by rys
Incorrect, if you press "Map View", then press "Record", it will trace. If you press "Map View" then "Stop" then it should stop recording, and then ask if you wish to leave the trace on the screen, or remove the trace.
(I had to sign in to the Lexus site to see the Nav manual to find this.)
-Brian
-Brian
That did the trick. I had a bunch of recorded markings and I was able to erase by doing what you said.
I must have pressed record sometime ago but I don't remember.
All is well now.
