View Poll Results: How much do you pay for oil changes?
20 bucks of less
2.60%
20 to 30 bucks
53
17.21%
40 bucks+
97
31.49%
I do it myself
150
48.70%
Voters: 308. You may not vote on this poll
Oil change stuff...
Old 07-11-06, 01:54 PM
  #31
kramo
kramo's Avatar
In some warrantee coverage situations the dealer will ask you to show proof of regular maintenance such as oil changes, etc. --- what if you're changing the oil yourself?
Would showing them receipts for oil and filters suffice? Could a dealer deny warrantee coverage because you changed your own oil?
Old 07-11-06, 02:57 PM
  #32
jezza
jezza's Avatar
No, they can't. Taken directly from the owners manual supplement, page 25 under the heading "Maintenance", which obviously no one here has bothered to read a word of:
You are responsible for performance of the required maintenance indicated in the Owners Manual and this supplement. Lexus will not deny a warranty claim solely because you do not have records to show that you maintained your vehicle. However, any failure or noncompliance caused by lack of maintenance is not covered by this warranty.
When maintenance and repairs are paid for by you, then services may be performed by you or by any automotive service provider you choose. Lexus will not deny a warranty claim solely because you use a service provider other than a Lexus dealership for maintenance and repairs.
Old 07-11-06, 08:16 PM
  #33
talalhz
talalhz's Avatar
I'll change mine at the dealer for the first time time, then later use Mobile 1
Old 07-13-06, 08:50 AM
  #34
06LexIS
06LexIS's Avatar
Your first oil change should be a complimentary one from Lexus, mine was. I also bought the pre-paid maintenance plan from them so both of my IS250's are covered thru 60K. Just remember that they are minor/major maintenance items as your milage increases, the biggest one at 60K if I remember correctly.
Check the manual or ask the dealer, also they have 10% off coupons that you can print online for oil changes.
Hope this helps.
Old 07-13-06, 09:27 AM
  #35
rys
rys's Avatar
I just called to find out if my dealer offered that prepaid maintenance option, they said no. Where did you get that service plan and is it dealer specific or is it from Lexus?
Thanks,
-Brian
Old 07-13-06, 11:10 AM
  #36
06LexIS
06LexIS's Avatar
When I purchased my car thru the Lexus of Pleasanton which is part of the Hendrick Automotive Group they offered it to me so I bought it. It's called the Hendrick maintenance care
I think its dealer specific @ 5K intervals.
Old 07-13-06, 04:19 PM
  #37
RshaoKh
RshaoKh's Avatar
Hope this helps.
Where do they have the 10% off coupons? I want some!
Old 07-13-06, 07:03 PM
  #38
GreyHound
GreyHound's Avatar
Default Has to be the easiest oil change
This thing is every bit as easy as chnging the oil in a Dodge Ram. Except you have to put the IS350 in the air a little. very easy. Oil filters I bought a pack of 10, Genuine Toyota, for about $4.89 each.
The oil is expensive, Valvoline syntec $4.67 a quart, you need 6.6 quarts.
Canister type, what is old is new again. Very nice, 2750 miles, drains real easy, no mess, nothing in the way. sent a sample off to get analyzed. If its this easy, I might keep it on a < 4k OCS.
Keep all reciepts Boys & Girls.
Got some crazy letter the other day from my dealer.Please bring the car in for a 4 month 4k mile check up. I don't think so. I'll take them up on the complementary change at 5k or so.
Its doing just fine thank you very much new filter on the left
Old 07-13-06, 07:05 PM
  #39
GreyHound
GreyHound's Avatar
Default canister is old school
This is the way it was in the 50's for you young'uns
after you get the filter off the car.
Old 07-13-06, 07:08 PM
  #40
GreyHound
GreyHound's Avatar
Default right under the fans
where the canister filter ls for you all that take it into the shop. Looking up throgh the little 'trap door' with the filter removed.
Three screws hold the little door in place.
Old 07-13-06, 07:18 PM
  #41
GreyHound
GreyHound's Avatar
Default You can do it !
$4.89 for the filter
$32.83 for seven quarts of Valvoline Syntec
The satisfaction knowing that nothing was cross threaded and the job was done right.
priceless
Old 07-13-06, 07:22 PM
  #42
GreyHound
GreyHound's Avatar
Default Where the green grass grows
Such a nice car !
Kinda glad I don't have to rotate the tires
Old 07-16-06, 05:18 PM
  #43
GOBUCS
GOBUCS's Avatar
Originally Posted by GreyHound
Such a nice car !
Hope your car doesn't slide off those boards while your under it .d The OSHA inspector would freak. What about some nice ramps??
Old 07-16-06, 06:40 PM
  #44
GreyHound
GreyHound's Avatar
Default Slide?
They're 2' x 10' s. How is it going to slide?
Solid, long, lay flat on the ground, car rolls easily up on them. Car is in park. I'm not removing the transmission or wrenching hard on it.
It ain't going anywhere. No jack anywhere in the area for the Osha cronies.
What do you call nice ramps? plastic ones that my neighbor used to drive over the end because they're so steep, or the metal ones that slide on concrete or drive themselves into the ground? Thats OK. I 'll keep my flat ones that are about five feet long and are about 15 years old. But I really do appreciate the concern.
What color was your IS 350?
Old 07-16-06, 11:51 PM
  #45
ES3
ES3's Avatar
Originally Posted by Payam
P.S. I went to Toyota for the second oil change, $29 with tax.
What's it cost at Lexus, 50 bucks? Also, did they do it while you waited? Loaner car if you had to drop off?
Quick Reply: Oil change stuff...
