In Mid-Hack - Question
One of my four vent clips won't snap down (passenger vent, left clip). I can pull it down as far as the others but it won't "snap."
Any suggestions?
Any suggestions?
The other three came down easily. This last one seems to be recessed behind the lip it needs to snap in front of (if you get my drift). It's not like the others. I wonder if it came broken from Lexus.
It does move down. Even as far down as the others. It seems like it's recessed too much and that's why it won't snap.
I was thinking that too. I was wondering if I could start prying the side that is down (the driver's side) and get a gap so I could push the clip down from the top.
I left my pick on top of the bad clip (with a pick I was able to get behind and on top of the clip. Keeping it down and using my fingers I got the #$@!&% out!
Super Moderator
Mine had the same thing happen, on the same one, passenger side clip. I heard a pop when i started doing it, because some post here way early on said to push up on the clips. Anyway, that lead to it breaking. So now one of mine doesn't clip down. I just work on the other side first and then put a screw driver inside to hold it down while i pry out the other end.
Everything was fine. I then put it in "Simple Mode" and now I hear no auido, even from the radio.
How do I get it out of simple mode. The manual says press the "SCAN" button 8 times in 1-2 seconds. I have a physical scan button so I can do that but it then says to press and hold the repeat button. I don' t have one and the Nav thinks there are no changers connected.
Not sure about the SCAN part, but it may be related to the fact that you installed in CD-MP3 mode (since you are already experiencing no sound with the radio)...check out my post after I installed it last weekend: https://www.clublexus.com/forums/sho...d.php?t=224916
In fact, I would be interested to know in what mode people with ML installed their Vais. In my experience, it only works in CD emulation mode...
Ed
