My Answer To The Tpms Problem
Originally Posted by BN06
Don't try to cross the border with that thing (Canadian at least). Good work, perhaps over-engineered but hey if it works it works.
How about a refillable aerosol spray can? one quick search yielded this item
http://www.nextag.com/60486443p/zz2zB4z23/prices-html
It says it can pressurize up to 50 even 90 PSI.
All you got to do is find a model that you can stick the sensors in.
I just don't know if the air will leak after an extended amount of time.
Originally Posted by c5mtl
why dont u mount a digital pressure gauge on it ???this way u know when the air is getting low.
I tried that on one of my first versions....but had leaking problems....this way seemed to work best
How did you mount the sensors in the PVC pipe? Did you just drop them in, tape, glue them so they are secure?
Also, can't you just put all 4 sensors in one PVC pipe instead of having 4 separate pipes?
Originally Posted by sanwong
IT IS SIMPLE PVC PIPE SEALED ON BOTH ENDS WITH A AIR VALVE ON THE END AND THE SENSORS VELCRO INSIDE.....AFTER WAS SURE IT WAS NOT LEAKING...I HAD IT VORTEX SRAYED TO COAT IT AND MAKE IT LOOK PRESENTABLE. I WILL MOUNT IT IN THE TRUNK
