Lugnut torque setting?
Old 07-12-06, 04:25 AM
riceboy22
riceboy22's Avatar
Just to append some definitive information to this thread, it's 76 ft.lbf (103 N.m) according to the owner's manual.
File Type: pdf
Old 07-12-06, 07:54 AM
shaolin
shaolin's Avatar
Originally Posted by al503
Even if the tire place uses a torque wrench, you should have them re-torqued after a few hundred miles just to make sure.
^agree.
and also, some torque ranch in tire shops may not be accurate anymore. Most of them don't have time to send them to get re adjust or buy another new one..
Old 07-12-06, 11:36 AM
Bichon
Super Moderator
Bichon's Avatar
Originally Posted by shaolin
^agree.
I've had enough hassle just getting them to use them; many tire shops around here will argue that using torque sticks on the air gun is just as accurate. ( Right )
I had a flat fixed at Stafford Tire in Middletown, insisted that they use a torque wrench, and the guy actually made me sign a waiver that they weren't responsible if the wheel fell off. (that was on my Audi, which used an 89 lb-ft torque!!)
At this point, I really don't trust many shops; I'll generally loosen and retorque to factory specs when I get home.
Old 07-12-06, 12:24 PM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Just get your own torque wrench. Its worth it.
Old 07-12-06, 05:36 PM
t0e
t0e's Avatar
https://www.clublexus.com/forums/sho...d.php?t=213773
Done!
StevieJ06
05-31-18 10:46 AM
Dommm
ES - 6th Gen (2013-2018)
01-15-18 03:26 PM
hornickel
08-17-14 03:05 PM
jtomanek
11-09-09 09:43 AM
Quick Reply: Lugnut torque setting?
