installing an amplifier
I've got an is360 with nav it, I wanna install one jl audio 300/4 for the speakers and one jl 1000/1 for two 12w7, is there an easy way to do this so I don't loose any of the functionality of my nav plus the cd changer?(so I could control the base and stuff from my nav screen) any help would be appreciated.
One 12w7 = way too much bass. Two 12W7 = you are crazy. If your not in some car shows or car audio competitions that much bass is not needed. For normal everyday music, my ONE JL audio 12w3v3 is PLENTY, and its only running off one channel from a JL 300/2. Dont get me wrong I love bass just as much as anycar audio guy but when I had 1 JL 12w7 it was too much, then I went down to 1 JL 12w6 and it was still too much. I am very happy with JL's new 12w3v3. Also on another note after your done with 2 w7's, amps, wiring, dynamat (you gonna need it with 2 w7's) and all that you will probably have 200+ more punds of extra weight that will slow the car down
yeah I know it's too loud for this car..but I don't want to sell it......it was in my bmw...but for now it's just sitting in my garage and I see it everyday...so I wanna use it....I'm gonna be building a fiberglass box and keeping it really tight so I don't load my car with extra weight......
and CMUSIC your system overview thread's awesome THANKS A LOT FOR THE HELP
hey this is for cmusic...I wanted to send you a pm..but didn't have your permission.....I wanted to ask a couple of things since you've already installed the system in your is.....1-...if I use the lc8 can I use the same wires for running the speakers from my amp?....and does lc8 have channel for the sub??...I'm just not sure how would I'll be able to run my 1000/1 for the subs?....just to let you know I've installed a few systems in my bmw and acura.....and I make my own custom fiberglass boxes...so I have some what idea about the systems......and I was thinking about putting 2 jl w7 in my trunk right behind the rear seat......should the sub face towards the rear seat...or away from it....would that make a difference?
thanks
thanks
Front left+ is light blue, front left - is orange
Front right + is black, front right - is gray
and the midbass (woofer) wires;
Front left+ is white, front left - is red
Front right + is brown, front right - is pink
to the first two channels on the LC8 and set the summing switch (which is inside of the LC8) to combine them together into one full range RCA output going to your JL 300/4. Use the crossover on the 300/4 set to highpass around 50 Hz or so to keep the dangerous low bass out of the front speakers.
Then I would run the four factory sub wires;
brown (+) / green (-) and pink (+) and light blue (-)
to the fourth LC8 input. Then from the 4th LC8 output run RCAs to the JL 1000/1. Use the LC8's remote level control to adjust the sub volume from the front. (You will have to run a wire [actually a telephone cable] up front for the level control.)
thanks
OC 335d
08-29-10 06:32 AM
Sheehan1p
14
02-24-10 05:44 AM
