Nav screen protectors
Originally Posted by ULTiMaX99
er? mine doesn't have a border...
the install should be easy... just peel it off n stick it on. i did have some trouble with putting it on straight tho. the top part of the nav gave me trouble because it has an overhang that just gets in the way. i also have 2 small air bubbles but you can't see it when the screen is on anyways.
Originally Posted by MeTrO
What seller or item number did you use? This will make aquiring one a little easier.
Originally Posted by jewel
Just ordered mine. How hard is the install? Whjat does it involve?
If it's the shieldzone.com one. It comes with a spray bottle, squeeqee (sp?) and the protector. You peel the protector off the paper, spray the back side of the protector and then stick it on the device (starting with one corner and applying it towards the opposite corner... to reduce bubbles). Then you push out any remaining bubbles, from the center out. All this is explained in the packaging that comes with the protector.
the ebay one is good... does the job. it's pretty thick for a piece of film. it won't fold over or crease...
do a search for is350 and youll see them. THey are the only ones selling them.
www.navprotector.com
seller is navscreen
seller is navscreen
The ebay one is like $5 cheaper but no 30-day money back guarentee and no lifetime warranty. They only except returns on unopened product. Their Page is wierd, every link says All New Models.
Hope this helps those of you who are hesitant to buy...
The one that I bought from ebay was perfect fit in size. I don't think I will spray water on the nav screen to align the film protector, just be steady and put it on straight. At first, I have a few bubbles on there, but it slowly disappear through the film and they are gone the next day, so don't worry about having small bubble in there as long as the screen is dust free. The best way to get the dust free is to roll up a small piece of scotch tape and then use it to get the dust off the screen without wiping.
I got it from this seller:
Ebay link to Screen Protector
