Lighting mods
Old 06-15-07, 02:06 PM
  #331
T4styPh0
T4styPh0's Avatar
Originally Posted by LexIS250SS
My car came with OEM HID and I would like to replace the stock HID bulb with 6000k or 8000k. My question is, if you have done this mod, did you have trouble replacing the bulbs? Thanks in advance
Nope not at all. I replaced my stock ones with 6000k from ijdmtoy. Theres a few threads on how to replace the bulbs. All you have to do is remove the windshield washer fluid pour neck, the 2 screws that hold down the airbox and take that off. Then remove the the caps with the yellow and black sticker. The bulbs are right behind there.
Old 06-15-07, 02:12 PM
  #332
llamaboiz
llamaboiz's Avatar
The question hes asking is, 'with a aftermarket conversion kit H11 to D4S can he use the OEM bulb with it'?
I myself dont know.
Old 06-15-07, 02:16 PM
  #333
T4styPh0
T4styPh0's Avatar
I myself dont know.
No, because the base of H11 bulbs are different from D4S.
D4S, on the box it says D2S but looks pretty much exactly the same.
Old 06-16-07, 11:37 PM
  #334
peterAP2
peterAP2's Avatar
Originally Posted by AzNLeX250
If you mean side mirrors: 168/194
Dome front: 3 168/194
Dome back: 2 31mm festoons
Vanity: 168/194
what size is the parking light thats always on? i wanna change that too..
Old 06-17-07, 12:23 AM
  #335
llamaboiz
llamaboiz's Avatar
Do you mean the lite that is always on when you drive in the day with the headlights off? Those are the DRL/high beam, type 9005 (hb3) bulb. The parking lite is a little 194bulb that lites up the area that the DRL/high beam bulb is located in.
Old 06-17-07, 01:10 AM
  #336
peterAP2
peterAP2's Avatar
sorry last question. what size is the reverse bulb?
Old 06-17-07, 01:12 AM
  #337
llamaboiz
llamaboiz's Avatar
I dont understand 'reverse bulb'.
Old 06-17-07, 01:37 AM
  #338
cspec
cspec's Avatar
Bulb for the reverse light. I think they are 194
Old 06-17-07, 03:51 AM
  #339
llamaboiz
llamaboiz's Avatar
OHHH... REVERSE LITES... haha... *cough* sorry but reverse is not in my vocabulary only GO GO GO
Old 06-17-07, 04:03 AM
  #340
T4styPh0
T4styPh0's Avatar
Reverse lights are actually 921 which is slightly bigger bulbs than 168/194 they still fit ok. Got the 168/194 LEDs in the reverse myself.
Old 06-17-07, 11:55 PM
  #341
peterAP2
peterAP2's Avatar
ahh... to many numbers..
what else do i need? i search some of the bulb sizes and couldnt find them on ebay..
my goal is to change out:
DRL's - 168
front dome light -- 168/194 (3)
rear dome light -- 31mm festoons (2)
back-up lights -- 921
cargo light - DE3022
glove box light - 37
vanity lights -- 168/194
the spot lights outside the door - 168/194
solved.
Old 06-17-07, 11:58 PM
  #342
llamaboiz
llamaboiz's Avatar
peterAP2, why dont you read thru this thread, all is explained...start on page1 and just go page by page... OR read the DIY stickys...
Old 06-18-07, 12:03 AM
  #343
peterAP2
peterAP2's Avatar
If i had all the answers then I wouldnt need to ask questions now would i? Its not like i havent figured out some of the sizes.
Old 06-18-07, 06:57 AM
  #344
T4styPh0
T4styPh0's Avatar
DRL's - 168
solved.
Correction, DRLs is the high beam on low power so it would be 9005. If you're talking about the little tiny bulb in the high beam area, that's the city/parking light.
Old 06-18-07, 07:27 AM
  #345
ben_r_
ben_r_'s Avatar
This might help some...
