Lighting mods
#556
It depends on which led's you choose, the real cheeper ones wont provide the amount of lite your looking for which why i always suggest you use SMT/SMD type lites.
hahaha i see your still on the fence on the mirror puddles
The PAPAYA DOME MOD 2white/1blue it will give you the brightness you want when the doors are open and the cool lighting effect you want once you close the doors. BUT if you choose to run 3 blue bulbs in the dome it will be darker than stock due to color of the light being 'blue'.
For the interior lights, it's not as much of a concern I guess, but I'd definitely like the puddle lamps to be brighter than stock.
#561
hi guys, looking for matching bulbs for the fogs with OEM HIDs...
i'm not too familiar with this kinda stuff...sorta new at it...but i know the oem hids are 4300K...
which fog bulbs would match the stock HIDs? dont want to go HIDs cause it's exp :S
thanks!
thanks!
#563
So....if I change the DRL's, I have to keep my high beams "on" in order to have them be white instead of that stupid yellow? (assuming I install some white leds in the drl's)
