Lighting mods
#587
#591
ok anyone who lives in toronto and wants to get those clear courtesy door lenses...don't they are like $23.10 EACH before tax much better off ordering from luxurymotorworks
anyways i have a question about the side mirrors...it doesn't seem to be on as tight after i ripped it out to replace the puddle lamps...i think it's that sticky stuff behind the mirror...anyone else have this problem? anyone know how to correct this?
thanks!
thanks!
#593
dont worry about this, i've done my mirror puddles 3times/countless club members cars and havent had any problems of 'looseness', as long as you snap the mirror on it'll be fine
#594
i always thought the black hooks at the side with the sticky stuff was suppose to hook to something when i first removed it, but if that was the case u can't really move the mirror left to right. i agree with u that its not as tight as before you removed it. but like llama said no problems so far.
#595
for all trying this...the bottom two clips are hard to snap back on...just give it a good ol' push
#597
drl wont turn on unless you start the car and take off the parking brake, if you turn on your lowbeams it wont turn on either, the idea behind led drl is how it looks in the day with the lights off not at night cuz then it wouldnt be called a daytime running light
#598
so after reading way too many LED posts, and realizing that v-led has changed there website from frickinbrite.com so all of the links that you guys posted about your leds are obsolete, i have a headache lol.
Can some summarize which 194 bulbs should be used for front dome/puddle and what festoons should be used for the rear from v-leds.com?
Thanks
Thanks
#599
have u become the guru of light? well the front dome u can use 194 hi power leds or 11 SMT LIGHT BULBS 194, ur gonna need 3 bulbs, the puddles u can use 194 flank bulb led and courtesy light and the vanity mirrors and puddles. if u have any questions just ask llama over there he is the guru of lights he will show u the way of the light.
#600
Sorry, decided to reply to this huge mass of a thread instead of starting the same redundant posts over and over again. I recently purchased one of these from v-leds:
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
(V-LEDS HID WHITE M-SMT FLANK BULBS 194) for my puddle lights.
It's a wedge type bulb so only one side will shine. However, upon installation I've found out that the side with the lights will not turn on if it's placed faced down (towards the floor). It will turn on if placed facing up, but you lose most if not all the light. So my question:
A. Is their a way to change the + - sides of the light bulb or socket to make it work "correctly?"
or
B. If not, does anyone have any experience with some bright bright lights that are wedge 194s (or fit vanity mirrors as well)?
I ended up installing them on my doors with clear lens cover and my god they are bright. I fell in love with them. It's a shame they don't work with puddle/vanity (or maybe they do?). Any replies, help, comments would be most appreciated.
P.S. Thank-you so much to all the D.I.Y guides and replies out there. Without them I would never have the nerve nor know how to "beautify" my "Alexia."
or
