Lighting mods
#663
There comes a point in lite mods when too much is a bad thing and less = more.
#664
Light gurus oh light gurus(llama), Have you guys used the HID DRL module+hardness from vled?http://www.v-leds.com/Shop/Control/P...7225/SFV/32481
I just bought some d4s bulbs and HID kits from cliffud, and i plan to be a guinea pig if no one has used it
#672
Yeah it's straightforward
I just put in my white ISPs and clear courtesy lamps on the doors in ~ 1 hour (I had to wire the ISPs too cause of 06
Use a little screwdriver covered with a microfiber to reduce risk of scratching!
#673
i know this is a real stupid question but by changing out the lights does it void the warranty ? ie. fog lights, puddle lamps, dome etc...
sorry about my noob question :P
#675
about bulb swaps and warranties... what are you worried about? blowing a bulb? *if it blows just put in a new bulb*, burning a harness? *dont put in a 100w bulb in a harness made for a 50w bulb*... bottom line, this is a non-subject if you just follow common sense.
