Lighting mods
#721
To be honest threre is no difference for me what to put Led or bulb and I don't know the difference between them. So I would like to have pretty the same color like 6500k. So what can you advise best for me?
Thanks a lot.
Thanks a lot.
#722
the difference is that if you go LED on the DRLs then you will no longer have highbeam function. if you're ok with that then get some cool white LEDs and the relay module, and those will match 6500K best.
otherwise if you're like me, get halogen bulbs and hope for the best. looks like most others who used PIAA had the Extreme White, the ones I got are Intense White which looks like a newer design and supposed to be more white.
#724
what do u mean hope for the best? so what is better bullbs or led? which color is going to be with bulbs? how bulbs will look with 6500k?
tnx a lot for help!!!
#726
the LEDs will look better than any halogen bulb in DRL mode. as llamaboiz explained using any halogen bulb for a DRL, the lower wattage used in DRL mode means the light coming from the halogen won't be at full power, and so it tends to be yellowish and therefore not that much of an improvement over the stock bulbs look. When you turn on highbeams that's when the bulb gets full power and then it will look nice and white. But I'm hoping that these Intense White bulbs which are bigger and a newer design, will look more white even at low power. I haven't received them yet but will try to take pics when I get them in... probably next week. If all you care about is looks not function and having the colors match best then go with LEDs.
#727
1. do you use your hibeams on a regular basis?
2. what are you trying to match? the drl? the hibeam?
one bit advise, read this entire thread, it will explain just about everything
#728
it appears you're confused and you need to learn what is the right questions to ask first... answer these question first:
thnx
#730
LEDs don't change intensity when you use it at half power or full power really.
Meaning they will be decently bright when they're on as DRL, but won't get to the brightness intensity that a normal bulb would go to when it's used as a HighBeam.
#731
I was curious, anyone try Sylvania SilverStar Ultras 9005 for DRL/HiBeams. Is there a noticeable difference?
Updated:
I just bit the bullet and bought these too. Spent $105 on 4 bulbs this weekend!
It is noticeably whiter up close, but probably from far away not so much. High Beams are definitely brighter and whiter, so that is good. Just hoping now that I can get DRL's disabled somehow and keep high beams.
Updated:
#732
DRL's are Highbeams at half power
#733
If all you care about is matching your DRL to 6500K, then go with the LEDs and live without the highbeam. The links to what kind you should buy is discussed throughout this thread.
If you care about highbeam, then you need to stick with halogen 9005 bulbs.
