Aww i wanted a brighter License plate LED. Its Really an assembly? Which i could put like 4 of those little IS F'ers on each side. That would make my license plate hella bright
Do you know if you're using D4S or D4R bulbs? Or is this a 9006 conversion? Looks like you either used the wrong bulb (or a defective one) or the bulb itself is not positioned correctly within the headlight housing.
Thanks for the replies guys. I'll bring my car back to the shop and replace the bulbs. See how it'll go. Hopefully problem will be solved
Hmmm do you have better quality pix? Looks like your lights have some weird half circle on the light... Do you see black half circle spots when you beam it to the wall? If you have big two half circle black spots, your HID needs to be repositioned. You have to turn it until those spot goes away. I had same problem so when I turned the bulb until it clicks into perfect position, those black spots were gone.
hmmm i got them for 12.50 each from my dealer, but i accidentally bought 4 because i thought the back would have them also, so I have a pair for sale if anyone wants it.
has anyone changed the center glove box light and the small little led in front of the dome light? what type of bulb it is and how to get to it. thanks.
