exterior temp therm.
Super Moderator
Two places. It's one of the display choices on the instrument panel display, which is chosen by pressing the "DISP" button on the steering wheel until it comes around. And it is also on the "Climate" screen on the nav display.
Super Moderator
Originally Posted by phatboyc
I think he meant the sensor for the digital thermometer. Not the readout.
I'm also wondering where.
On my previous cars with such displays, the sensor was located near the air opening in the front bumper, in a place where it would see incoming air when the car is moving, yet be sheided from the brunt of radiated heat from the A/C condensor and radiator.
My educated guess would be that it's in a similar location in our cars, for the same reasons.
1. On coming air blows to the back of the vehicle, so you want it in front of the engine, radiator and A/C condensor.
2. Heat rises, so you want it lower than the engine, radiator, and A/C condensor.
I'm curious about this as well. On my previous car (Audi A4), the temperature probe was too close to the engine bay, so it always read about 4-5 degrees too high.
This weekend the outside temp on the IS350 read 122 degrees in Rowland Heights, CA (Los Angeles basically). I know it was friggin' hot this weekend, but 122 still seems a tad high.
Super Moderator
Yup, to piggy back off of what Bichon said, you've gotta give ur car a few seconds before taking the temp seriously because it'll cool off by 4-5 degrees as you drive off. The reason why it's always high as you first hop in the car is because the sun's been beating down on the sensor while your car is parked but the minute you drive off, the temp lowers to what the actual temp should be.
I have seen this difference too,and I have to imagine that some of the difference is the heat radiating off the pavement. The radio/weather stations thermometers are probably mounted somewhere with less radiational heating.
We were driving near Woodland Hills on Saturday (that’s the northern valley portion of Los Angeles) around 3pm and the car’s reading said 117 degrees!
What? That must be an error. But no ,sure enough, the TV news later said the high for the day in the valley was 117, breaking the all-time record.
We’re suffering in the heat here, but at least our IS readout is accurate.
Mine always reads really hot when I first start the car, but once I start driving, it will cool off a bit. Sometimes it's right on the money, but other times it can be a few degrees high...
