One the phone...
Old 07-28-06, 06:32 AM
BShears
BShears's Avatar
Default One the phone...
I read this in a thread months ago but I can't find it.
If I get to work and I'm in the middle of a phone call I'd like to turn off the engine without cutting off my conversation. How can I do that? I know I can pick up the phone and switch from the hands-free to the phone but I'd like to leave the speakerphone connection going and just shut off the engine.
Old 07-28-06, 07:11 AM
Bichon
Super Moderator
Bichon's Avatar
Put the car in neutral and press the engine start/stop button. The engine will be shut off, but the car will remain in accessory mode. Once the engine is off, you can shift to Park.
Old 07-28-06, 09:58 AM
BShears
BShears's Avatar
Bingo! Thanks
Old 07-28-06, 10:51 AM
VitB6
VitB6's Avatar
How can you change from handsfree to the phone without cutting off the conversation?
Old 07-28-06, 11:00 AM
Salil022
Salil022's Avatar
you can switch from handsfree to handset without getting disconnecting, you just go under options on your phone while the call is active and it should say handset, just select it and you are good to go!!
Old 07-28-06, 12:12 PM
ULTiMaX99
ULTiMaX99's Avatar
any method like this for the manual???
Old 07-28-06, 01:22 PM
Kermee
Kermee's Avatar
If you have NAV, hit the "Transfer" button the screen. That disconnects the handsfree back to your phone without disconnecting the call.
My Treo has a "disconnect" on the screen so usually I just hit that instead because the "Transfer" button is greyed out while the vehicle is in motion.
Cheers,
Kermee
Old 07-28-06, 01:57 PM
Payam
Payam's Avatar
Cheers,
Kermee
I think it's time for someone to do the nav hack....
larry09
07-01-09 10:31 AM
daryll40
05-15-09 05:50 AM
jenters
02-25-08 01:53 PM
juncho
06-20-07 01:05 PM
dfw350
03-03-06 06:21 PM
Quick Reply: One the phone...
