19" Ruff Racing Wheels
19" Ruff Racing type 278, 35 offset, Hyperblack.
Kumho ECSTA SPT
235/35/19
275/30/19
Noticed the Kumho's are slightly wider than other brands. I have some rubbing in front and will use the heat gun to cure. I also have some rub in the back with passengers. Is rolling the fender the only way to fix the rear rub?
Kumho ECSTA SPT
235/35/19
275/30/19
I selected the Kumho's after reading about them on Tire Rack. I did not want to end up with too ruff a ride and the Kumho's looked good for ride and for handling, so I got them. The Kumho's are a little more firm riding than stock but that was expected with a lower profile. What I can't tell you is how well they handle. After about 4 miles the TPMS light came on and sure enough, the left rear was a flat. So, I have three new Kumho's and one new something.
I'll have a new tire here on Monday the 31st. That's when I plan on taking my aggressions out them. I'll let you know how they work then.
Originally Posted by ULTiMaX99
doesn't seem like it... but are you lowered?
Not lowered. I think the 19" wheel and tires help close the gap some.
Originally Posted by Wests
for the rubbing in the rear you just need to cut out the little lip on the inside of the fender.
I went back to the shop where I purchased the wheels and tires. They were able to roll the lip with a tool made for this exact purpose. Best part is they did not charge me a dime. NO RUBBING!
Originally Posted by glilly
it was the +35 in the rear that's caused your rubbing.
Bingo!, the fronts and rears are a +35 offset.
Adding to the offset problem is the Kumho tires. They are especially wide. My 275/30/19's are more like 285's in width.
The shop I purchased them from used a lip roller to fix. All is well now.
