GPS Positioning problem
Old 09-15-06, 11:11 PM
  #46
chicolex
chicolex's Avatar
Man I am telling you right now, if your dealership is acting up and being an *** you should call or threaten to call lexus headquarter. When i bought my car, the salesman noticed that the finance people didn't treat me very well and he took me outside and told me not to tell lexus headquarters, as a reward he gave me BIG BIG discount on services and products. I think they'll get in trouble if customers complaint and not many customers now this. Competition is tough out there
Originally Posted by rekognize
since i last posted the problem i have been to the dealer 2x and both times they claimed it was fixed but as i drove home the nav began to stray off course. i am finally scheduled to bring in the car again tomorrow but they are hesitant in giving me a loner car despite the fact that the car obviously needed more than one day with a grease monkey. anyone know the protocal on loner cars?
i bought a lexus based on the looks of this IS and the reputation of quality of service was undeniably a factor in my decision. unfortunately, my dealer has NOT been very helpful nor has lexus customer service which responded to my complaint via email 2 weeks after i emailed them of my complaint. even the response was awful...(paraphrase) "we will investigate and a representative will contact you in 3 - 5 business days"...i'm still waiting lexus?
about 2 years ago mercedes was having problems with the E-class electronics. I forgot the specifics of the electronics problem but I recall mercedes replacing the cars of those that were affected. thats great customer service...i cant even get a freakin' call back from these guys, what gives?
it is also quite apparent that i am not the only one facing this problem. if anyone has further info on this matter please help with a reply. i am hopeful of my 3rd visit to the shop. i hope the knuckleheads will finally listen to the fact that recalibrating/"rebooting" is not the answer to the problem. i believe its the hardware...the antenna? or it can be that cpu someone mentioned earlier.
AAAAAAAHHHHHHHHHH!!!!
-mike
Old 09-17-06, 07:39 AM
  #47
Bichon
Super Moderator
Bichon's Avatar
Originally Posted by The Chad
Yes, and no. 3 satellites and it can locate your position, because it trianguates your position. However, if you get 4 satellites, then the system can detirmine your altitude, which makes it even more accurate.
I have observed that on the "GPS info" diagnostic page, three satellites causes the status line to change to "2D", but the when I change back to the regular map screen, I don't see the "GPS" notation under the map scale. That notation doesn't appear until at least four are locked.
Anything less than 3, and your SOL and the system just works on speed sensor input and perhaps a steering sensor / gyroscope. It's pretty accurate in tunnels, but if you do any significant turns without a satellite signal, it'll lose you quickly.
I'm guessing that you aren't suffering from this problem, because this isn't what we've observed. I've driven for hours without the GPS signal, making many, many turns, and had it stay nearly as accurate as when the GPS signal was being received. Without the signal, it uses both the speed sensor and a gyro as input (you can see the outputs of these on the info/light stalk diagnostic page). But that's only part of its bag-of-tricks. It also makes the assumption that you are driving on a road. So if there is a road within a few hundred feet of where it thinks you are, the pointer automatically snaps to it. That takes care of the "X" axis. Make a 90 degree turn, and that takes care of the "Y" axis. It isn't until the system makes a mistake and snaps to the wrong road and doesn't figure it out in time to snap to the right road, that the system gets very confused and inaccurate.
Old 09-18-06, 05:47 PM
  #48
rokeven
rokeven's Avatar
I have had my car in 6 times now, they have replaced the disc, the nav "brain", and broke my mirror off the window. My nav still doesnt work. They showed me where to check the list of satellites and told me to look at that whenever it messes up. It is always connected to 5-7 satellites when screwing up. My dealer did tell me the antenna is located in the back window. Any idea if that is true???
Old 09-18-06, 06:40 PM
  #49
EBMCS03
EBMCS03's Avatar
False, its in the front dash. Middle, slightly off to the right.
Old 09-18-06, 06:41 PM
  #50
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,996 Likes on 2,420 Posts
Yeah, what he said.
Old 09-19-06, 06:08 AM
  #51
Bichon
Super Moderator
Bichon's Avatar
Just because you see the satellites listed on the diagnostic screen doesn't mean that the nav is getting a clean signal from them. Did the dealer tell you to check the signal and status columns? I look for satellites to have a status of "P". I believe the ones where the status is blank or "T" are not getting a usable signal.
In my case, as soon as I see four birds with a "P" status, I have GPS lock.
(Also, for some unknown reason, my GPS system seems to be improving. I'm getting a lock about 3/4 of the time now)
Old 09-19-06, 08:15 AM
  #52
rekognize
rekognize's Avatar
The dealer's been working on my car since thursday and still no word...i aksed about the CPU for the NAV that someone mentioned earlier and my customer service rep laughed and said there is no such thing. its quite obvious that they have no clue whats wrong with it.
regarding my car being a lemon...since i paid extra for the nav system wouldnt the defective nav be enough to considered the value of the car impaired?
Old 09-19-06, 08:19 AM
  #53
rekognize
rekognize's Avatar
the purpose of the nav is to make our lives easier...for the dealer to expect us to constantly monitor and check the validity of the system is irrational
Old 09-19-06, 08:48 AM
  #54
rekognize
rekognize's Avatar
shouldnt the gps get a lock 99.9993% of the time?
Old 09-19-06, 10:16 AM
  #55
CarDudeRI
CarDudeRI's Avatar
Count me in on this problem now too. Only happened 2 times. The first time I don't remember the details of the day (how hot, where i was, etc)... but the second time was recently. Driving thru Boston, 65 degree night, car parked in a parking garage out of the sun all day. System showed me being about 4 streets over from where I actually was. Could it be the buildings interfering with the signal? I know this isn't the cause for everyone's problem, but could it be the cause of mine for this one instance?
Old 09-19-06, 12:02 PM
  #56
rokeven
rokeven's Avatar
my car seems usually has 5-7 satellites with a "P" next to them. Other than that there seems to be 2 that occasionally show a "T". I drove home yesterday (25miles) with that screen on the whole time and saw it drop twice to no signal from any satellite and about 10 seconds at a time. It happened on open road, no overpasses / tunnels, and no trees either. Suddenly all the satellites would come back. weird.
Old 09-19-06, 03:58 PM
  #57
kensteele
kensteele's Avatar
probably. i just think it would be difficult to win a battle over the proper operation of equipment which is subject to government-owned satellites some 12,000 miles in outer space. especially if it is not operating at peak performance as opposed to simply not functioning at all. ymmv
Old 09-19-06, 10:48 PM
  #58
lobuxracer
Tech Info Resource
lobuxracer's Avatar
That sounds like a bad power or ground connection to the GPS receiver. If it loses power, all the satellites will go out.
I had a mystery problem with my Supra that ended up being a single pin on the ECM connector that would only connect when the cabin temperature was more than 55F. It took the better part of a very cold day to determine exactly where the problem was. I was ready to tear my hair out trying to find the fault too.
If we have a poorly built, poorly chosen, or poorly designed connection to the satellite receiver/amplifier, it would explain these intermittent problems and possibly the thermal aspect of the problem as well. It doesn't explain how you could have 5 - 7 birds in sight with lock and drift off though.
Old 09-25-06, 03:25 PM
  #59
Operation
Operation's Avatar
Default Jamming Issues
Hi Guys,
Just posting my .02. As an employee of a GPS chipset manufacturer, I can tell you anything you need to know about GPS.
I'd be willing to wager this is a jamming issue from some electronics close to the GPS antenna/module. A car is a very noisy place especially one jam-packed with electronics like the Lexus. It's also possible the antenna is sub-optimal or the connector is loose or the GPS receiver isn't properly shielded. In-band jamming, would explain a lot of the issues you guys are seeing (long cold-starts, position jumps, etc). Radar detectors, metalic tint and even cell-phone modems can cause interference issues. LCDs are also a notorious source for GPS jamming.
I can say with strong confidence this isn't a heat issue. Unless, I am wrong here, most of the Japanese auto mfg's use a Nippon company called Furuno (you might be familiar with their fish-finder consumer products). In any case, the Furuno receiver is spec'd to the automotive temp. operating range of -40 to +85C. That's right celsius. I doubt any of you operating your vehicles anywhere close to the maximum ratings.
Old 09-25-06, 03:36 PM
  #60
lobuxracer
Tech Info Resource
lobuxracer's Avatar
So the coincidence of bad positioning and 150+F temps inside the car are purely coincidental?
Why would it self-correct as the interior temperature drops?
Is there a local oscillator or a passive component that could be heat affected?
I agree about the chips, they are generally pretty good at temperature. Quartz crystals are not as good. The ones I had in my Cesium and Rubidium clocks were wrapped in thermal blankets to maintain a very constant temperature and minimize drift. Any chance this might be happening here enough to lose lock on a satellite?
Also, on a Google, I'm finding two levels of permissible thermal range - one is -20 to +70C, the other is -40 to +85C. I have no trouble believing the dashboard gets up to +70C when it's +42C outside as it was here in Sacramento last summer.
Quick Reply: GPS Positioning problem
