GPS Positioning problem
Old 11-14-06, 10:09 AM
  #106
ES3
ES3's Avatar
Originally Posted by Pete C
Unfortunately, no.
Bummer!!!
Old 11-14-06, 07:18 PM
  #107
ecr527
ecr527's Avatar
Okay, I guess I'm the latest one to experience this problem. I purchased my IS the last week of December and just started having this problem last night. I noticed that on my drive home last night it was off 5-10 miles. At one point I was driving down a side road parallel to Florida's Turnpike, and it even put me on there for a little bit. Since it was so far off, I decided to try and set home as my destination and see what it would do. Since it was so far off course to begin with, it kept on having to recalculate the route. Then at one point, it jumped back on course and worked fine for the rest of the night. Tonight it did the same thing. I'm going to watch it for a few days and see if the problem persists.
I may make an appointment to have the dealer check it out since I've had the screen go out on me a few times while driving. It went to a black and dark grey striped screen for a few seconds then came back on.
Old 11-15-06, 07:47 PM
  #108
MR LEX
MR LEX's Avatar
@ ecr527
Make sure and wait until the 6.1 version is "officially" released (end of this month) before you make your appointment. Otherwise you will end up with the upgraded 5.1 disc like I did
Lexus basically told me that they gave me the most up-to-date disc at the time my appointment was made.
I'm currently negotiating with Lexus on the subject...
and yes, they removed the software override
Lex
Old 11-15-06, 07:55 PM
  #109
Technique
Technique's Avatar
BTW, there is a V5.1 U30 disc that does have the override... I guess it must be this latest U30 disc that doesn't... Strange that they would release two versions of the U30 disc...
Mr. Lex - Can you confirm the part # you posted above? It doesn't seem to confirm to any of the other discs I've seen...
Old 11-15-06, 10:30 PM
  #110
MR LEX
MR LEX's Avatar
I'll do one better by posting an image of my disc
Lex
Old 11-21-06, 10:26 AM
  #111
Technique
Technique's Avatar
Lex
Any luck posting the picture?
Thanks!
Old 11-21-06, 03:50 PM
  #112
dkaplan435
dkaplan435's Avatar
Originally Posted by rekognize
Hi...
my IS nav system has been acting up lately. at first it was locating my car about 5 miles, then 10 miles. after i recalibrated the position using the setup function, it worked fine for 30 min then reverted back to la-la land, about 30 miles away.
anyone else experiencing this problem?
thanks,
mike
There is a TSB on this, #EL013-06... You can get a DVD w/ an OS upgrade, under warranty. I'm not sure if that new OS will do away with the ability to push a few buttons and fool w/ the destination while driving..
Old 11-21-06, 03:55 PM
  #113
Technique
Technique's Avatar
can you post the full tsb?
Old 11-21-06, 07:39 PM
  #114
ES3
ES3's Avatar
@ ecr527
Lex
Please let me know where you get on this! I'm in the same boat as you, would rather have the upgraded mapping!
Old 12-21-06, 10:53 AM
  #115
bturnbaugh
bturnbaugh's Avatar
Default When to get a new disk?
My Nav has got lost a few times but mostly because it was on this new road that is not in the system yet. It bugs the me to death! Am I to get the new disk next year?
Old 12-22-06, 07:53 AM
  #116
clubfoot
clubfoot's Avatar
There is a TSB and a newer version disc to fix the GPS problem.
Old 12-22-06, 08:06 AM
  #117
Bichon
Super Moderator
Bichon's Avatar
The replacement disk that the dealer installs as part of the TSB has exactly the same map data as the original. Only the software is new.
If the poster is having problems because he is driving on streets that aren't on the map (as opposed to having the nav lose position because the GPS won't lock - GPS indicator under map scale off), the TSB won't help. To fix that issue he'll have to purchase an updated map disk when it becomes available.
Old 12-22-06, 08:08 AM
  #118
AsianGirl007
Lexus Diva
AsianGirl007's Avatar
Mine doesnt recognize my home address and my building is old. It does recognize my front neighbor's address though. Go figure.
Old 12-22-06, 08:47 AM
  #119
Tchan1
Tchan1's Avatar
Same problem happened to me a month ago i had to unplug the battery and let it sit for a few mins, then I plugged it back in and it was fixed. For my 15k service I told them about this problem and they are ordering a part to fix it. When I asked him what part are they ordering to get it fixed, he said that its just a dvd to recalibrate it. The part is not here yet, so I'll just have to wait and see what happens.
Old 12-22-06, 09:15 AM
  #120
Bichon
Super Moderator
Bichon's Avatar
The replacement DVD has nothing to do with recalibration, it simply updates the software in your navigation system to a version that is better able to lock onto the satellites. I haven't had a problem since the dealer replaced my disc, and noticed on the diagnostic screens that the system is able to see and lock about double the amount of satellites than it used to.
Quick Reply: GPS Positioning problem
