10k oil change
Originally Posted by Leechiro
wolverine...so that silver thing is the oil filter? im only asking cause for what little i know about cars, that doesnt look like a filter, but maybe the NEW IS has something different.
where are the 3 10mm bolts located, i have yet to get under my car. does wolverines picture show the bolts that are needed to be removed? or can someone upload a pic or draw one for me? id liek to take that to the shop and let them know what to do so they dont overcharge me, thank you.
Part 2 of the question is about the bolts. The three bolts in this picture are already removed. The black square hole around the filter is normally covered by a small flat panel hiding the filter. You can see the 3 bolt holes in the picture tho. One in on the bottom of the square hole right in the middle. And the other 2 are on the top of the square hole. One on the right one on the left. This is what holds the panel on. The panel and actual bolts are not shown in this picture as they were removed. Hope this helps. JIM
One more add to comment on the price and stuff of the place your taking it to. 1 Either they are lying to you about the whole cover being removed or they havent ever worked on a 06 IS (which might be the case). They are also chargeing over double the list price on the filter. If you walked into your local dealer the filters going to be less then 7.00 with tax. 13.00 is a nice mark up for them. This is just one of the many reasons why i dont take my car in.
shyishguy
08-22-07 07:12 PM
