Navigation: Change Destination While Driving
Old 08-06-06, 02:17 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,972 Likes on 2,403 Posts
Thanks for the clarification. That's what I thought I read in all the nav hack threads. Now if I could just disable the voice prompt for the voice commands and go straight to the beep...
Old 08-06-06, 05:59 PM
MeTrO
MeTrO's Avatar
Now THAT would be a nice feature.....takes 10 minutes just to dial a phone number....waste of time. The only command I even THINK of using is "75 degrees" and "I'm hungry".
Old 08-06-06, 07:49 PM
Pete C
Pete C's Avatar
One of the menu options in the Setup menu will disable the voice prompts and go straight to the beep. I forget which one it was that I used, but I no longer have voice prompts. Give it a try.
Old 08-06-06, 08:51 PM
MeTrO
MeTrO's Avatar
How?....where??
Old 08-07-06, 06:05 AM
Pete C
Pete C's Avatar
Press Menu, then Setup. There are options regarding voice guidance. (You'll need to use the arrows on the left of the screen to get to pages 2 and 3). I don't recall exactly what it says, but I recall it sounding more over-arching than it was, i.e., it sounds like you'll be turning off all voice guidance for the nav, also, but you won't be. Sorry, I can't be more specific, but I'm not in the car to get the exact wording for you. I'll check later, but I'm sure you'll be able to figure this out for yourself based on the information above.
Old 08-07-06, 08:53 AM
Magellan
Magellan's Avatar
Originally Posted by Poison*Ivy
Navigation does not allow me to change destination while driving. My salesman told me this is a safety feature to prevent distraction while driving. I am on the road a lot and often need to change my route. Is there a way to override this feature? I do not see this listed as a personal setting option.
I don’t know what all the fuss is. Instead of changing a destination just cancel it and put in a new one via the voice recognition feature. You can do this while driving.
It may take a minute or so, but IMHO beside the nav-hack being a potential safety hazard, it makes doing so unnecessary.
Old 08-07-06, 01:03 PM
romwarrior
romwarrior's Avatar
You can turn off the voice prompts for regular voice commands, but it doesn't affect the dial by number voice prompts. They are still there and it does take forever...
jonmanch
ES - 6th Gen (2013-2018)
01-15-14 08:13 AM
nmtomcat
RX - 3rd Gen (2010-2015)
12
09-10-13 07:37 PM
miniz
ES - 5th Gen (2007-2012)
11-04-11 03:49 AM
FrankWhite
01-03-08 01:48 PM
jmgoldsmit
12-09-07 05:24 PM
Quick Reply: Navigation: Change Destination While Driving
