stoptech for the is350 is now available!
#61
What pad choices are there for the IS stock brakes? I would highly recommend simply swapping a race pad for track days before spending $6k on brakes. Many race classes do not allow big brake kits and people get by just fine on stock brakes with race pads and ducting. In fact, sometimes they remove the ducting as it doesn't allow the pads to get to optimum temps. Another benefit is that stock rotors, which have to be considered a consumable if you track your car, are usually cheaper than some gonzo 355mm one. I certainly would not spend the money before trying different pads and, even more importantly, trying to brake less. It slows you down after all.
#62
What pad choices are there for the IS stock brakes? I would highly recommend simply swapping a race pad for track days before spending $6k on brakes. Many race classes do not allow big brake kits and people get by just fine on stock brakes with race pads and ducting. In fact, sometimes they remove the ducting as it doesn't allow the pads to get to optimum temps. Another benefit is that stock rotors, which have to be considered a consumable if you track your car, are usually cheaper than some gonzo 355mm one. I certainly would not spend the money before trying different pads and, even more importantly, trying to brake less. It slows you down after all.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Race Classes: I don't know of any tracks/clubs that don't allow BBK's. If you're referring to certain class of car/setup in competition, then it's a different story.
Ducting: has already been discussed in this thread. There probably isn't enough room under the car to get any ducting with an adequate diameter without the fear of scraping, etc. If someone could design something that works, that would definitely be the way to go but you wouldn't get the bling.
Rotor Costs: when the rotors are worn out in your BBK, you can just order the rotor and re-use the hat. Prices are very comparable and to swapping the OEM rotors out with new ones.
#63
Send Carbotech some old pads and they will make you new ones in any compound you want (Porterfield may do the same). I mentioned racing as an example that stock brakes with the right pads are up to track work. I drive a 3800lb car on track so I have been through this. I am an advanced driver and although my brakes are not "stock" in the U.S. they are factory brakes (they do have a 4-piston fixed caliper and floating rotor up front) and work fine with simple wheel well ducting and track pads. I can get a slightly soft pedal at Laguna but otherwise they are fine. I know many E46 M3 owners that have had success with stock brakes and the right pads on track. $6k is half a decent Spec Miata!!
BTW, I would assume that an advanced driver would also be swapping pads on the Stop Tech brakes anyway.
I went and checked out their website and even plain rotors (without hats) are $225-$250 each. Street pads are about $150 and race compounds are about $250. A stock vented rotor would run that much from Lexus?
#64
$3,195.00 for the front!! @..@
Wow~~~ that must be installed...
Is this mean... Brambo's more expensive? Or, Stoptech makes better brakes??
#65
Guest
Posts: n/a
U still come visit! What u dood
#66
I still can't get over the fact that people will actually spend $6,000 to put new brakes on their car. How many of you guys buying these brakes are up to your eyeballs in debt? How many of you are silver spooners? Just curious.
What a stupid "investment" in a car that was designed from the ground up to be a sporty Buick. I could see if you were building a track car, which is something that the IS will never be...
#67
Hey 1Sicklex.
The site happened to come up in a google and I realized I hadn't been here in a while.
ff_,
Sporty Buick is a bit harsh but I agree $6k on brakes is overkill. But....it does look good.
ff_,
#68
Everything is relative. Why don't you go onto the other forums that have some seriously expensive rides and ask them the same thing. Some people wear seikos, others wear a rolex, and still others wear a patek phillipe.
I'm not a religious person but the phrase 'judge not....' seems overpoweringly appropriate here.
#71
#72
Stoptech will be the first to say and they do say that the rears are very optional as it does very little actual braking. The rears with SS lines, good fluid, and race pads should do the trick. They make the rears available for the hardcore lapper and for the person who wants a balanced look.
As I mentioned previously in this thread, tracking a car is a very expensive proposition ($500-$700/day not including a day without pay). Spending $2600 on the front kit isn't that far out of line all things considered.
So you use it for as long as you own the car, send it back to stoptech and have it reconditioned for a few hundred bucks and sell it for 50-70% of what you paid for it depending on how many lap days and condition. (I got 68% back from the Endless kit I had on my G coupe for 2 years.) Sure they cost a lot but I got the benefits and peace of mind at the track and the bling for 2 years for a fraction of what they cost.
You're right that the stock brakes properly prepared and equipped haven't been proven inadequate. Maybe they'll hold up, maybe they won't.
I see the BBK as good insurance, which is expensive but the best money you ever spent if you need it.
#74
Going with stickier tires will add that much more punishment to the brakes. You should upgrade both if you can.
I didn't see it myself but there was a c5 vette running R compounds with the stock brakes (race pads, fluid and lines). The front rotor failed and the vette was totalled. Luckily, the driver and instructor got out with sore necks, seat belt burns and a little ringing in the ears from the airbags.
From that point on, a BBK was a must for me. If for nothing else, it's good insurance, gives me peace of mind, and is worth every penny.
Have I mentioned the bling when you're not out on the track?
#75
Tech Info Resource
because everyone driving my car feels the difference that the brakes respond faster? like someone said before, it could be the ss line alone, i never said it's the calipers. but one thing very clear is that on my cars, the brakes become very sensitive, slight touches and the car chok to stop already. me and my wife had to completely relearn braking. reducing response time is just as important as braking time, and if pressing the brakes lightly can yield the results of pressing the brakes more in stock setup, that's obvious improvements to me.
