stoptech for the is350 is now available!
#76
Tech Info Resource
Going with stickier tires will add that much more punishment to the brakes. You should upgrade both if you can.
I didn't see it myself but there was a c5 vette running R compounds with the stock brakes (race pads, fluid and lines). The front rotor failed and the vette was totalled. Luckily, the driver and instructor got out with sore necks, seat belt burns and a little ringing in the ears from the airbags.
From that point on, a BBK was a must for me. If for nothing else, it's good insurance, gives me peace of mind, and is worth every penny.
Have I mentioned the bling when you're not out on the track?
Regardless of who makes your gear, you really do need to inspect it carefully before any track day. Especially wheels, tires, and brakes. And every site sponsoring track days I've seen says you need to bleed brakes, inspect tires, and check your brake pads before arriving at the track. Sound advice for sure.
#77
That kind of failure is way more likely to be a cracked or thin rotor (as you said, inspect before you track the car) then a factor of R compounds. I don't see a BBK as a safety feature. If you are losing braking due to heat you should be paying attention and know it -- just like you should know when your tires have gotten a bit hot and you don't have the grip you had the lap before.
I will say without hesitation that of the many, many experienced track junkies I know most will recommend not buying a BBK.
#78
#79
I would just like to say - I hereby volunteer to be a stoptech guinea pig. Please send me front and rear brake kits, as well as 2 stoptech stickers and I will gladly market your beautiful brake kits.
#80
I talked with the nationals sales manager. You can imagine how many sponsorship requests he gets.
#81
Tech Info Resource
ROTOR, Supra, w/Turbo, Right 93-94 $76.26
ROTOR, Supra, w/Turbo, Left 93-94 $76.26
From Champion Toyota in Houston. 5 years ago they were only $65 each.
This has something to do with it for sure. Especially when it's a 320mm curved vane 30mm thick disc. The hat isn't the most expensive part of the proposition, and you have to replace the attachment hardware when you replace the rotor itself. OK, you don't HAVE to, but you'd be foolish not to.
#82
I don't know how much the rotors are for the IS but it's probably closer to the G's than the Supra's.
#83
Tech Info Resource
The design and execution is almost identical. The IS just has another 14mm of disc. It will be criminal if they are priced like some of the other discs.
I priced front brakes for an STI and I was stunned to see the OEM parts going for $300+ per disc. Pads were also $300+. The only excuse I got was Brembo is expensive. Except Brembo makes OEM replacement discs for a number of mundane cars that are competitively priced with the (really cheap) OEM stuff.
I hope the IS isn't as ridiculous as some of these others are.
#84
I'm very interested here. Could you elaborate on reasons?
I don't want to tell you how to spend your money but most newbies barely threshhold brake anyway. I would at least wait until it is clear your stock brakes with a good pad are not getting it done.
My comments about a soft brake pedal only pertain to the comment that a big brake kit makes it "safer" on track.
#85
Are these solid rotors that have been drilled or are they engineered with holes in place? I hear that this causes a lot of durability issues along with a slew of other issues?
#86
They have drilled rotors but they don't recommend those for the track. Solid or slotted will do just fine on the track.
