Blackstone UOA results of break-in oil
So, you did in fact run the original oil for almost 5,000 miles and the report came back good? I have always changed at 3,000 miles and was not sure about the recommended 5,000 mile oil change. With these facts, then 5,000 miles should not be an issue? Thanks!
2IS OG
Originally Posted by Gernby
I replaced it with Mobil 1 5W-30, and plan to change it again at 10K miles. Depending on the UOA and TBN at that time, I may extend my OCI to whatever Blackstone recommends.
Javier
Actually, like most manufacturers, Lexus has 2 recommended OCIs. The "regular" OCI is 7500 miles, and the "severe" OCI is 5000 miles. Once break-in is complete, I'm confident a good oil (Red Line, Amsoil, etc.) would be fine with 10K OCIs and maybe a filter change at 5K. However, I will probably just stick with Mobil 1 and change it at 5K or 7.5K intervals based on future UOAs (and no track days).
2IS OG
Agreed. I change my oil at the "extreme" interval because all of my driving is short, city trips (usually less than 5 miles) with lots of L.A. traffic and hardly EVER any highway driving, unfortunately. Sooooo, I'll be sticking with my Royal Purple/Mobil1 every 5K - it's just too cheap not to...
Javier
Javier
If you look online, you'll find the 5000/7500 mile option, but I'm pretty sure they screwed up and are presenting the information for the IS300 under the IS250/350 heading.
That being said, I doubt you'd have any issue running 7500 miles or more on a good synth.
On another note, I'm glad you went with blackstone on the break-in oil. I'll be changing mine out shortly, so it'll be interesting to compare the two reports.
Originally Posted by jezza
Not according to the owners manual. There's zero mention in the manual or service supplement that anything other than 5000 miles OCI's are permitted.
