see i knew they would probably fit.........i have seen 25mm offset volks on a 350 with a eibach drop, all they had to do was roll the fender. YES post pics up!
do you have pictures of this 25mm offset rims is350??
I HAVE AN IS250 WITH 18X8.5 38 OFFSET IN FRONT AND 18X9.5 WITH A 30MM OFFSET, WITH A ONE INCH DROP, LOOKS PERFECT. NO RUBBING IN THE REAR , DO NOT HAVE ROLLING FENDER. WILL POST PICS SO YOU CAN SEE.
It seems to me like running so little offset in the rear would make it look too much like a street dragster / muscle car since you definitely wouldn't be able to run such agressive offsets in the front.
