30mm offset in the rear
Old 08-09-06, 06:31 PM
kilo6_one
kilo6_one's Avatar
Default 30mm offset in the rear
guys, im curious........
would a 30mm offset on a is250 work in the rear? I currently have a 38mm offset and i was told it may fit since at aspec products they were able to fit 350z rims on a IS350 with a little fender rolling.
Old 08-09-06, 06:33 PM
4TehNguyen
4TehNguyen's Avatar
many people use mid 40s for the rear, probably going to rub
Old 08-09-06, 06:36 PM
kilo6_one
kilo6_one's Avatar
yeah, i was worried about that.........
i just dont want my rims to be sunken in, the 19x9.5 i have now is almost perfect, and should be pretty much flush with the fender once its camber is adjusted.
Old 08-09-06, 06:39 PM
suprafrank
suprafrank's Avatar
30mm offset in the rear??!!! It may not look that good.
Old 08-09-06, 06:45 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,003 Likes on 2,425 Posts
You have a rear camber adjustment? Which 250 do you have?
Old 08-09-06, 10:28 PM
kilo6_one
kilo6_one's Avatar
what i was trying to say was i need to get an alignment......not camber adjustment sorry. long day .........
yeah, 30mm may be too agressive.........
Old 08-09-06, 10:38 PM
pocky
mooncake master
pocky's Avatar
+30 would be a bit too aggressive for the IS. Unless you get a smaller rim width, then it's doable. But you lose alot of tread on the inside.
If you are doing a 9.5" width rim. My suggestion would be +35 or +36 if you want to trail on the aggressive side.
Old 08-09-06, 10:54 PM
kilo6_one
kilo6_one's Avatar
currently i have 19x9.5 with a 38mm and it is almost flush with the fender..........yeah, it may not be worth it.
thanks everyone for your imput
Old 08-10-06, 08:12 PM
LOUIESIMO
LOUIESIMO's Avatar
Default 30mm Offset
I HAVE AN IS250 WITH 18X8.5 38 OFFSET IN FRONT AND 18X9.5 WITH A 30MM OFFSET, WITH A ONE INCH DROP, LOOKS PERFECT. NO RUBBING IN THE REAR , DO NOT HAVE ROLLING FENDER. WILL POST PICS SO YOU CAN SEE.
Old 08-10-06, 08:16 PM
kilo6_one
kilo6_one's Avatar
see i knew they would probably fit.........i have seen 25mm offset volks on a 350 with a eibach drop, all they had to do was roll the fender. YES post pics up!
Old 08-24-06, 07:29 AM
scsrock
scsrock's Avatar
Does anyone know the offset of 17" IS250 stock wheels?
Old 08-24-06, 07:43 AM
4TehNguyen
4TehNguyen's Avatar
first post of the first page of the aftermarket wheel sticky shows stock wheel specs
Old 08-24-06, 10:41 AM
Gernby
Gernby's Avatar
I have 18x9 with a +35mm offset with OEM tires, and I can't believe that they don't rub.
Old 08-24-06, 11:37 AM
scsrock
scsrock's Avatar
I found it. Thx.
Old 08-24-06, 12:53 PM
IS_250
IS_250's Avatar
if you're really curious, grab some spacers and test fit them on behind your current wheels. grab a 5mm universal spacer just to test fit and see how much clearance you have.
Quick Reply: 30mm offset in the rear
