don't mess with the vdim...
#62
Originally Posted by flipside909
VDIM is always on.
Just a reminder to everyone, the pedal dance is the VSC/TRAC disable...not VDIM disable.
#64
I'm guessing that if the 07's do come with a switch it will be something like the CTS V's and Corvettes. It will alow more slip or instability but not be totally off. The CTS V I test drove had 3 modes of stbility control.
#65
True but it doesn't disable ABS, Brake Assist and VGRS which are integral to VDIM. The pedal dance was designed as a dyno mode for diagnostic testing purposes. It works on the 05 and newer Toyota Avalon, IS250, GS300, GS430. To date, the GS300 and IS250 and Avalon don't have VDIM.
Check this thread for info. I posted links to what VDIM is and how VSC & TRAC function.
https://www.clublexus.com/forums/sho...d.php?t=229847
#66
#68
More on VSC/TRC Control for '07
Regarding changing of TRAC and VSC operation permission / disablement through VSC OFF switch
(1) Changing modes
Through the VSC OFF switch, the vehicle can be changed to normal mode, TRAC OFF mode and VSC OFF mode.
1. Normal mode
When the vehicle is in TRAC OFF mode or VSC OFF mode, and the VSC OFF switch is pressed for a short amount of time, the vehicle changes to normal mode. During normal mode, TRAC and VSC operation is possible. After the ignition switch is turned ON, the vehicle is in normal mode.
2. TRAC OFF mode
When the vehicle is in normal mode and the VSC OFF switch is pressed for a short amount of time, the vehicle changes to TRAC OFF mode. During TRAC OFF mode, the combination meter's slip indicator light illuminates, and TRAC operation is disabled. During TRAC OFF mode, if the vehicle speed increases, the vehicle automatically returns to normal mode.
3. VSC OFF mode
When the vehicle is stopped and the VSC OFF switch is pressed for 3 seconds or more, the vehicle changes to VSC OFF mode. During VSC OFF mode, the multiinformation display shows a VSC OFF display, and the combination meter's slip indicator light illuminates. Also, VSC and TRAC operation is disabled. During VSC OFF mode, even if the vehicle speed increases, the vehicle does not return to normal mode.
(1) Changing modes
1. Normal mode
2. TRAC OFF mode
3. VSC OFF mode
#69
3. VSC OFF mode
#70
Sorry, forgot to include this note:
The same deal for the TRAC OFF mode. Hit the switch again briefly and TRAC is restored.
When the VSC OFF switch is pressed for 3 seconds or more with the vehicle stopped, the VSC system changes to VSC OFF mode. If the VSC OFF switch is pressed again with the system in VSC OFF mode, the TRAC and VSC systems can be operated. When the system is in VSC OFF mode, the SLIP indicator light and VSC OFF indicator light illuminate.
#71
#73
I dug into this more today for awhile. The '06 combination meter (dash instruments) is different. The '07 has another indicator for VSC off. It doesn't exist on the '06, so I seriously doubt there will be any retrofit capability. Unless you want to swap out the gauges and the skid control ECU. I'm fairly confident the lawyers will not permit a reflash without an indication the VSC is disabled. At least, that's what I expect. So, those of us with '06s are pretty likely to be out in the cold on this.
