Which are better tires?
Overall, I think the Dunlops are better, but in reality what matters is the tire size you pick and the line from the manufacturer. Most companies will provide several lines, at different prices, with different types of construction. Check to see which line from which manufacturer gives you the features you look for in your tires and you will be set.
Overall, I think the Dunlops are better, but in reality what matters is the tire size you pick and the line from the manufacturer. Most companies will provide several lines, at different prices, with different types of construction. Check to see which line from which manufacturer gives you the features you look for in your tires and you will be set.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I was under the impression that the Dunlop's have the better tred life. I've got well over 13k miles on my IS350 paired with the Dunlop's and still have plenty of tread.
Depends on how you define "similarly". I'd say that the difference in performance between the tires can be significant to the trained driver, especially as evidenced in the comparison between the stock Dunflops, and the RE-050's. The RE's are a much better performing tire. And what is considered "at the limits" for the Dunflops, are not as close "to the limits" for the RE's.
Stock Dunlops SP Sport Maxx are on mine and they are very good...to me pretty sticky. They should last at least 20K miles with agressive driving, perhaps 25K which they are closey rated for. I plan on changing them at 20K.
I obviously have not had the others stock bridgestones, but many have complained about the sub 18K miles of tread they are getting.
You usually have to choose. Do you want a tire that's going to last a long time? Or do you want a tire that's going to perform in a superior way? Choose one.
