Where to get wheel spacers for IS350??? (Update & pics on pg.4)
Old 08-17-06, 07:50 AM
  #76
Gernby
Gernby's Avatar
Originally Posted by t.is350.h
Nice, I was thinking 12mm for the front too. I saw some guy go +32 offset and haven't had any problem yet. Keep us post after you install it.
Was this +32 on an 18x8 with stock tires and suspension? I imagine that he might have problems if he lowered it.
Old 08-19-06, 11:49 AM
  #77
Gernby
Gernby's Avatar
I just changed out my front lugs with the H&R studs. I can't believe how easy it is! You don't even have to take the caliper or rotor off!
Old 08-19-06, 12:06 PM
  #78
javyLSU
2IS OG
javyLSU's Avatar
How did you get the stockers out? Did you just tap them with a hammer? I'm gonna do mine soon...
Javier
Old 08-19-06, 12:21 PM
  #79
Gernby
Gernby's Avatar
Here is the view from behind the knuckle showing the access hole to the lugs.
Attached Thumbnails Where to get wheel spacers for IS350??? (Update & pics on pg.4)-100_0240.jpg
Old 08-19-06, 12:24 PM
  #80
Gernby
Gernby's Avatar
Just hammer the old lugs out with only as much force as is necesary.
Attached Thumbnails Where to get wheel spacers for IS350??? (Update & pics on pg.4)-100_0241.jpg
Old 08-19-06, 12:26 PM
  #81
Gernby
Gernby's Avatar
Insert the new lug and lock it in place using a lug nut and an impact wrench until it is fully seated.
Attached Thumbnails Where to get wheel spacers for IS350??? (Update & pics on pg.4)-100_0242.jpg
Old 08-19-06, 12:28 PM
  #82
Gernby
Gernby's Avatar
When you put your wheel back on, you should probably over-torque the lug nuts to make sure the lugs actually are fully seated, then loosen and torque them again to spec. After driving a few miles, check the torque on the lug nuts again.
Old 08-19-06, 12:36 PM
  #83
Gernby
Gernby's Avatar
BTW, I have no idea if the rear lugs will be as easy. I suspect that they WON'T.
Old 08-19-06, 02:53 PM
  #84
t.is350.h
t.is350.h's Avatar
Gernby!
How thick is your spacer in the front?
Nice write up. Thanks for the info.
Old 08-19-06, 03:23 PM
  #85
javyLSU
2IS OG
javyLSU's Avatar
Great pics and write-up! Why do you think the rears will be more difficult? If I had to guess I would think the fronts would be more complicated than the rears... Or do you think access to the rear of the lug is going to be an issue?
Javier
Old 08-19-06, 04:43 PM
  #86
Gernby
Gernby's Avatar
Javier
Thanks. I think the rears will be more difficult because of the CV joints.
BTW, my spacers are just 5 mm.
Old 09-25-06, 12:05 PM
  #87
STIG
STIG's Avatar
I am thinking 20mm for the rear and 15mm for the front?
What do you all think?
Oh and anyone know where can i get these H&R spacer the cheapest?
Thanks.
Old 09-25-06, 12:16 PM
  #88
javyLSU
2IS OG
javyLSU's Avatar
15mm is going to be too much for the fronts (unless you actually WANT the wheels protruding from the fender). Mine are 12mm front, and 17mm rear - if I were you I would go 10 and 15 (front and rear).
Javier
Old 09-25-06, 12:19 PM
  #89
Gernby
Gernby's Avatar
Thanks.
That will be too much for stock wheels and tires. The largest spacers I would try would be 15 rear and 10 front, especially if you ever plan to run wider tires up front.
Old 09-25-06, 12:51 PM
  #90
STIG
STIG's Avatar
Thanks! Then I will go with 10 and 15mm.
Quick Reply: Where to get wheel spacers for IS350??? (Update & pics on pg.4)
