full synthetic oil
Blackstone's analysis might be good, but their tech's readings of those numbers leave a lot to be desired in many cases. You can entertain yourself over on bitog.... believe what you please, it makes little difference to me, my point was just that a 5w30 shearing to a 5w20 isn't earth shattering news.
Tech Info Resource
Maybe this needs reiteration - TSB EG006-06 says as of March 29, 2006, ALL new Lexus vehicles are getting ILSAC GF-4 5w-20 as their standard fill, from the factory since February, 2006. So anyone taking delivery by the end of March or later very likely had 5w-20 oil in the crankcase.
5w-30 shearing to 5w-20 in less than 5k miles is news, and should never happen in a car engine that quickly. In a bike, sure, it goes through the transmission and suffers a lot of mechanical damage from the clutch and gears, but in a car engine with a gerotor oil pump?
Did you clean and re-oil your K&N? If you did, you might want to get some contact cleaner and shoot the hot wire in the MAF (very, very, carefully!) to remove any oil that might have got on it from the filter.
OR, did you buy gas from a place that laces it with alchohol? You will always get less mileage from a gasoline/alcohol mix. It has significantly lower specific heat.
I've been buying gas from the same 2 stations I've always got it from. All of them switched to E10 earlier this year.
i don tknow, call me retarded ...what is ILSAC GF-4 and do you recomend using the dealer to do the oil, or would it be ok to go where it take all my cars? and when would it be ok to switch to full synthetic, i ask becuase i know that the service intervalls are longer then the standard 3k miles..i just dont want to foul something up.
I must swallow my pride, and admit that I was wrong about the oil causing my reduced fuel economy. I still don't know what the deal was, but I've been averaging over 22 MPG for weeks, and haven't changed a thing that I'm aware of.
Anyway, my apologies to those that I argued with above.
No apologies necessary, don't sweat it, it's all good. We were all just brainstorming along w/you to figure out your mpg drop. I have a new theory - when you installed your JoeZ & HKS, the ECU may have detected the change and started running richer to compensate for the add'l air flow ?!? After a few weeks of normal running, the ECU self adjusted again and now you're back to status quo mpg - your oil change just happened to coincide with the install of the intake/air filter . . .
I seriously doubt the minor intake mods could have been "detected" in any way by the ECU. I think the cause had something to do with my driving habits, as others suspected above. Although I was methodically trying to get good mileage, it just wasn't working as well then as it is now.
EDIT: It could have also been a bad tank (or two) of gas.
I wouldn't discount your intake/air filter mod, other forum members have posted that the JoeZ intake adds 5-7 rwhp on their dyno runs, add the HKS filter and it's no longer a 'minor' change. If the ECU can detect octane drop and retards ignition, it should also detect the added air flow. Either way, you're back to normal mpg, so life is good again . . .
Tech Info Resource
The ECM doesn't detect octane drop. It detects audible knock in the cylinders. It doesn't care what the source of the problem is (octane, overheating, clogged injector, etc.) it just defaults to retarded ignition timing to prevent the engine from detonating itself to death.
More or less air means nothing to the ECM. It's using a wideband O2 in front of the precat to determine a/f ratio and set it to what the ECM is expecting (maybe stoich, maybe not). The only time the intake could possibly affect a/f in a bad way is at WOT, and even then, when you consider how small a hole you need to make 306 hp, the intake is massively oversized. Yes, the first couple of minutes you change something it will upset the correction factors, but short term trim will kick in very quickly and sort that out, even at WOT.
Well, it's truly personal preference and everyone has a different opinion. I still prefer dino oil, but I'd bet that most folks choose Mobil1 - it's reasonably priced and available just about anywhere. IMHO, you should try to stick to one brand rather than buy whatever synth happens to be on sale before your next change . . .
Tech Info Resource
Brand isn't a big deal. Availability is probably one of the more important features. Exotic synthetics may be pretty hard to find if you need to top off and you're far from home.
