Headers/TRD
does anyone have any info on the megan headers? are they any good and are they worth it, i also noticed they have a whole cat-back system, what are your guys's thoughts on their products and is it worth it?
Tech Info Resource
Yeah, they're illegal on smog controlled vehicles. You're in CA. They're for "off-road" use only. No cats. Illegal to remove this exhaust header under Federal law because it removes a functioning catalytic converter from an emissions controlled vehicle.
Pretty simple, isn't it?
Tech Info Resource
You'll need documentation for why you replaced the cat. Federal law prohibits removing a cat from a vehicle unless it is damaged or clogged, or the vehicle has over 100k miles and it is being replaced with a like unit. That's not a guess, I've read the law myself.
Besides, a large share of the gain with headers is from removing the "pre-cat." The cat right up next to the exhaust port is there to start working as quickly as possible and meet cold cycle emissions requirements. The distance from the head is critical to quick light up.
A good header design won't merge the three cylinders until much further downstream, at which point the cat will not be able to meet cold cycle requirements. This is what killed the TT Supra in '98 for California. It was legal in 49 states, but not CA because it couldn't light the cat up quickly enough for CARB.
I'm certain Lexus would have preferred to make a better header, but it's not possible to meet the emissions requirements AND have a solid header design. They did the best they could given the design requirements and time allotted. If the aftermarket comes up with a solution, it will likely be "off-road only" and if you decide to run it here in CA, you'll be swapping your stock header back on the car every time you smog.
Tech Info Resource
Texas compliance is completely different than California compliance. Smog checks here are not just tailpipe. They have a visual component, and they have pictures of what your engine bay should look like. They also check the hoses and compare them to the hose map. If you have anything that deviates from stock, it has to have an E.O. number issued by CARB indicating it has been reviewed and approved by the state as not changing the car's emissions.
If you happen to be in a SMOG Check II area, they also put the car on a dyno and test it at street speeds (15 and 25 mph) under load to be sure everything works as intended. They also check your ECM codes, so even if you've put everything back to stock, if it has a stored code indicating there was a problem, you will have a problem passing smog.
It's a huge PITA for enthusiasts. The general populace just accepts it blindly as a cost of cleaning up the air. The State HAS to do this or lose Federal highway funds. So, we the people, get screwed twice. Once by the smog checks and twice by our own tax money being squandered on crappy roads that don't seem to be getting any better.
Tech Info Resource
They look specifically for the cats. You can't design a good header with the position of the OEM cats. The runners are too short and uneven. You'd have to do some really good NASCAR style trickery to make the OEM configuration into a decent header. I don't think it's possible.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Hopefully someone will work on a header for the other 49 states.
