Intuitive Parking Assist? Worth It
from memory. when you get close to an object, your entire nav screen will switch to the pa screen. the little display next to your speedo will also switch over.
an outline of the car shown from above will show multiple yellow radar-like waves at the corner or corners / front you are near. there is a steady beeping. as you get closer, the yellow radar-like waves become less and less and the beeping increases. when you get really close, yellow turns to red and the beeping almost becomes solid.
I do not have the parking assist on my car as for whatever reason it was not available at the time of my purchase. I do however have the backup camera and that is more than sufficient. My mother's LS has the parking assist. It seems pretty helpful as it shows you a skeletal image of the car on the Nav screen with audible tones and visual lines showing how far you are from an object. I would not however, recommend getting it after market as they cannot match the paint on the sensors to that of your car as if it came from the factory, so the sensors will just be black. They also cannot tie it into the Nav like the facotry does. My understanding is that the after market parking assists ar just audio. Doesn't seem worth it to me unless you get it from the factory.
There's no disable switch on the IS ? The LS has an on/off switch for PA, so you can temporarily disable the system when stuck in stop & go traffic. I don't recall if the PA display came up on the Navi screen, I'll have to check that out next time I drive my parent's LS . . .
Liquid Bra Champion
Completely disagree - ever been to a sporting event and have to park in a structure ? I've been stuck in a parking structure in a long line of cars trying to go out the same exit, and you will very easily set off ANY PA system - it's just the nature of beast. Getting stuck is irritating enough, add to it the constant beeping from the PA, a couple of screaming kids in the back and you have the recipe for a nice migraine . . . no thanks - gimme a PA defeat switch.
The rear sensor is active while in reverse, and the corner sensors when the car senses the steering angle and/or object, but how would you regulate a front sensor (anyone with aftermarket have experiences)?
Perhaps road debris damaging the sensor was also a concern, as the manaul does specify that you must be careful about protecting them from shock/impact.
I'd lastly imagine that front crash regulations (including those for pedestrians), along with the cars aero design (and fascia support), didn't provide adequate space for a sensor.
Super Moderator
Liquid Bra Champion
Originally Posted by ff_
I think the point was that if you were driving that close at higher speeds, that would be foolish. I don't think he was referring to inching along in a slow line of cars.
"you don't want beeps going off while stuck in traffic situations, where the car can't make the distinction between parking, and not."
I at least hope nobody is attempting to park their car at 60 mph.
The manual states that the distance at which the rear sensor begins to sound (used since its opposite of the front), is around 4.5 feet- a measured test in my vehicle came out to roughly 4.7 feet. When in traffic, people travel at this distance all the time, which would drive a sensor nuts should it not have its range configured to be appropriate.
