Redline
I'm a newbie here...so a welcome would be nice.
anyway here is the point of my post. I was out for a nice little drive here in northern va. Since my crystal white IS350 (sport package & ml) had reached it's 1000 mile point I decided to push it a little on the highway. Soo, I pulled into a parking lot and started the car with the VDIM disabling sequence and all. I then proceeded to pull up to the stop light, dropped into manumatic mode (1st gear). As the light turned green I punched the gas almost all the way while making a right turn. The car vaults forward like a barbaro at the kentucky derby, wheels screeching, almost getting completely sideways before straightening out. In the heat of the moment, as i have only heard my 3 week old IS do this once or twice from the power brake stance, I forget to upshift. I notice that in less than 2 seconds the car was riding at 7000 rpm, and the shift light is yelling at me, saying wtf are you doing dumbass?!? There was a sinking feeling in my heart. I felt as though I had taken 3-5 years off the life of the engine doing that. has anyone else done this??
don' sweet it, that's why there is a rev limiter, plenty people hit it due to the slight delay in shift, also the car reaches the limit so quickly
An F1 car can accelerate fast is because of high power to weight ratio. An F1 engine can produce lots of bhp because it can rev up to 20,000rpm. The torque of the engine is only slightly better than your normal everyday car engine. If the book say your max power is at 6400rpm. Then try to change gear at around 6000rpm since it takes a few milliseconds to make a gear change. If you change when you see the needle is pointing 6400rpm, chances are the car probably change gear at higher revs eg 6800rpm. The power curve on most cars usually drop significant after it reaches max power. So it you do that, your acceleration time actually would be slower.
Tech Info Resource
Didn't I say someone would say I'm wrong?
You missed the whole point about the F1 cars. In the late 80's when they had turbos, they made twice the torque they do now. Then, as now, the cars have no trouble accelerating hard. The weights have not changed significantly, but the rules have. The engineers solved the problem with rpm and gearing. They accelerated hard then and they accelerate hard now with half the torque they had when they had turbos.
Sure the power drops after the peak, but what if it only drops 20hp and shifting to the next gear from peak drops you 40hp? The point is, it's smarter to sit down with your dyno chart and your gearbox spreadsheet and analyse where you should be shifting, not blindly shifting at peak power. It's really rare that shifting at peak will net best acceleration. In the case of the IS, it is hard to imagine why shifting at or below peak power would be worthwhile since the engine holds steady hp over the last 1500 rpm before redline.
I'd personally rather shift at 306hp at redline to have the rpm drop and put me back at another point with the same 306hp instead of shifting as soon as I get to 306hp and drop down to 250hp. It won't feel as fast, but it will definitely be faster if you measure it with a watch.
Man sorry to hear about that. That sucks!! Same thing happened to a friend of mine before his engine was broken in. We both have identical IS350 sport models with about 7500 miles on each of them now. Unfortunately for him, his car can't stay with mine. Right off the line, straight on up to 100+mph, he tails me. We have been racing for months now and he never wins. I hope speed is not important for you.
Just mess'n with you! You'll be fine. Enjoy the car!!
Don't worry. As others said once a while is ok. Later on it should be fine to do that more often. My IS 350 is more than 5K miles now and I pushed it to 6.5K rev most of the time. I set the limit light at 6000 or so. It's fun to feel it going fast.
I probably spent an hour total time bouncing the rev limiter in my S2000, and it never showed any negative effects.
I also believe that shifting at the rev limiter will generate the best performance on just about any car, especially in the lower gears. Even if power drops off 60 HP, the gearing advantage of 1st over 2nd is way more significant. When I plotted out my HP to the pavement (dyno plot combined with gearing ratios) through all 6 gears in my S2000, there was a clear advantage to shifting at fuel cut all the way.
Tech Info Resource
With an 83mm stroke, we're not anywhere close to violating mean piston speed limits at 6500 rpm. The only possible issue would be valve train problems, but again, at only 6500 rpm, it's very unlikely even with the rocker arms they used. Honda used excatly the same kind of set up (rocker arms and hydraulic adjusters) in the Nighthawk 750 way back in the mid 80's, and they were easily good to 10k rpm.
I bet you could over-rev the 2GR to 7500 without being worried in the slightest. I'd also bet the 2GR that Team Lexus is using redlines around 8700 rpm. With the right port work and cams, I can easily see another 150 hp out of this engine with that redline.
For the technogeeks:
Mean piston speed at 7230 rpm = 20m/sec
Mean piston speed at 8680 rpm = 24.01m/sec
This engine isn't stressed hard at 6500 rpm AT ALL.
Tech Info Resource
Rocker arms limit valve actuation speed. Toyco/Yamaha used them to make the head more compact, but direct valve actuation (a la 2JZ, 2AZ, 1ZZ, etc, etc) would not be limited the same as a rocker arm. They behave like springs at very high speeds and they add mass to the process. The 2AZ uses buckets without shims (variable thickness on the buckets) and they weigh about 15g total.
Given the choice to use either, I would always opt for the buckets.
Tech Info Resource
Yeah the peak number gets a lot of undue attention. The real meat is area under the curve - specifically where you plan to operate. If you compromise the peak number to get more area under the curve (because you need it), then sure, torque wins races.
But anyone who's been doing this for a minute knows if your powerband only needs to be 3k rpm wide, then build for best torque in that 3k rpm, and don't even bother with the rest of it. Who cares if a race engine idles at 1500 rpm?
Street duty is a completely different animal. Nobody wants to idle at 1500 rpm. Nobody wants an engine they have to rev to 3k rpm to pull away from a stoplight. So, you have to build differently. Torque needs to peak early and be as flat as possible. So everything is different - cams, ports, exhaust, tune - it's all got to match intended purpose.
If you want a really interesting study in torque, look at generator sets. Those engines operate in an extremely narrow rpm range, and everything is optimised to make lots of torque in a range of about 10 rpm. The Miller cycle was originally developed for just this purpose. Ship engines are very similar because they trim for best speed/unit of fuel used. Outside that range, they're worthless.
