A Track Day at Willow Springs
Old 08-20-06, 07:58 PM
talalhz
talalhz's Avatar
Exclamation
Admin Remove
Old 08-20-06, 08:47 PM
rsx2is350
rsx2is350's Avatar
More pics, More!!!!
Old 08-20-06, 09:12 PM
Hartawan
Former Vendor
Hartawan's Avatar
In the first picture, it looks like the IS is about to run those little Celica's over. How much does it cost to go to a track like that? Any special license?
Old 08-20-06, 09:36 PM
suprafrank
suprafrank's Avatar
Nice!!!! Did you get to experience some drifting at the corners??
Old 08-20-06, 09:59 PM
al503
al503's Avatar
Can't tell from the pics if there is an instructor or not. Local clubs usually have HPDE's (High Performance Driver Education) lapping days where you go out with an experienced instructor who gives you instruction.
They usually run $125-$150 (at least where I live) per day. That's somewhat deceiving as you'll definitely use a lot of gas, and your wear items (brake pads, rotors, tires, etc.,) add up very quickly.
I figure each trip costs me at least $250-300 in just tires as I scrub off 2-3/32nds and can get around 4 track days / set of tires.
It's definitely worth it though and you may get hooked.
Old 08-20-06, 10:14 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,469 Likes on 1,774 Posts
Nice pictures.
Those Celicas GTS and S2000 are taking corners completely flat out so I can bet they are faster in the corners. However, they simply do not have the raw brute power to keep up with the IS350 on the straights (I doubt even the S2000).
Old 08-21-06, 06:53 AM
Gernby
Gernby's Avatar
Were these actually racing slicks, or just R-compounds? Were you running OEM brake pads? How long were the lap sessions? I'm asking because I think this could prove that some of the super expensive brake upgrades being discussed are unnecesary.
Old 08-21-06, 06:55 AM
Payam
Payam's Avatar
Originally Posted by rsx2is350
More pics, More!!!!
Old 08-21-06, 07:01 AM
ff_
ff_'s Avatar
Actually, they don't have the massive weight to tow around either, so I'd guess the S2000 is even faster in the straights. When you compare the RWHP numbers for the S2000 (2004+ model) and the IS350, they put down almost the same power. Yet the S2000 weighs, what, 700+ pounds less.
Old 08-21-06, 07:09 AM
Salil022
Salil022's Avatar
not sure if S2000's put down same horsepower to the wheels, my buddy has one with intake, headers, exhaust and we did 3 runs, one from the start and other two rolling and i pulled hard on him by atleast 3 car lengths. From the light our car has an amazing accelaration.
Old 08-21-06, 07:19 AM
05RollaXRS
05RollaXRS's Avatar
S2000 stock puts down 200 - 205 whp and I believe the IS350 is around 245 - 250 whp? So even with the 700 lbs less weight, the IS350 should still out run the S2000.
Old 08-21-06, 07:25 AM
gsrthomas
gsrthomas's Avatar
If vdim never beeped then you werent driving hard enough.
ff_
ff_'s Avatar
The 2004+ S2000 dyno's at ~ 240 HP to the rear wheels, IS350 puts down ~ 246. In a drag race, the S2000 has to be wrung pretty hard to get revs up into the "power" range, because its torque peak is quite high. The IS350 has the benefit of a meaty torque band, so less "wringing" is necessary. With rolling starts, the difference in torque will be even more obvious. Your friend's shifting ability will also make a large difference. The S2000 is capable of 0-60 sprints in the 5-5.5 second range, so we know that it'll match the IS350 when properly driven.
But get the S2000 on the track with a properly trained driver, and it will spank the IS350 up and down.
Old 08-21-06, 07:27 AM
gsrthomas
gsrthomas's Avatar
In an autocross its not about horsepower. An S2000 can surly win an IS350 on an autocross track. Its about the driver skill and the cars handling. Old people with 100k Porsches get smoked all the on these tracks with cheaper less espensive cars.
Old 08-21-06, 07:37 AM
05RollaXRS
05RollaXRS's Avatar
Yes I had said that before that the S2000 would be quicker in corners without a doubt. It was more about who would be quicker on the straights.
Quick Reply: A Track Day at Willow Springs
