Spoiler Installation Question
Old 08-22-06, 11:22 AM
StockIS350
StockIS350's Avatar
big spoiler, wind @ 100 mph, I'll make sure I don't drive behind you guys that double stick their spoiler
Old 08-22-06, 12:15 PM
ihkskim
ihkskim's Avatar
you know mercedes benz use 3m tape on their lip wings unless you're like this guy who 1/2 asses a big spoiler
Old 08-22-06, 12:47 PM
MeTrO
MeTrO's Avatar
That tape ain't coming off unless your REALLY REALLY want it to. Most lip spoilers are held on with just tape. I would rather lose a $200 spoiler than risk a $1200 (guessing) trunk lid to damage, rust, mis-drilled holes and so-on.
Old 08-22-06, 12:54 PM
t.is350.h
t.is350.h's Avatar
Originally Posted by Flipsonic
Yeah I think I will be drilling. I hear it adds 10 hp when bolted on.
13.5hp to be exact......
Old 08-22-06, 01:38 PM
Flipsonic
Flipsonic's Avatar
It's always good to know that I can install it with 3M tape. Worst case, if I really screw it up and the holes aren't aligned, I will use the tape. But I'm confident it will turn out perfect bolted on. Thanks for all the feedback.
Old 08-22-06, 02:09 PM
Gernby
Gernby's Avatar
I just drilled the holes "big enough". They were ugly when I was finished, but it turned out fine. I considered just taping it on, but felt like I would get a better alignment if I followed the installation instructions (pull the tape backing off after bolting it up and centering it).
Old 08-22-06, 02:19 PM
Flipsonic
Flipsonic's Avatar
Hey Gernby, I plan to use just the 8mm drill bit. It says 12mm on either end but the studs looks like they will fit in the 8mm holes. Should I go back and get the 12mm bits? They look pretty big. Also Home Depot didn't have a 12mm hole saw.
Old 08-22-06, 02:24 PM
Gernby
Gernby's Avatar
I don't even know what size bit I used. I just grabbed a bit that was bigger than the bolt. After drilling the holes, they weren't lined up well enough, so I had to elongate them. They all looked like bullet holes by the time I was done.
Old 08-22-06, 05:59 PM
HaveBlue
HaveBlue's Avatar
They probably recommend the 1/2" bit on the outside in case the holes don't line up; you will have some play.
Old 08-22-06, 07:44 PM
Flipsonic
Flipsonic's Avatar
Well, I just installed it and I'm happy I bolted it on. It took 45 minutes. It's perfect except I could not get the nut on the center stud on no matter what I did. I don't know if it is stripped or what. I'll try another day since it's getting dark. But both ends are secured. This baby ain't going nowhere. I won't bore you with pics. You've seen one, you've seen them all.
Old 08-22-06, 08:50 PM
menech
menech's Avatar
I feel safe driving behind you again flip now the trick is passing you heh
Old 08-22-06, 10:03 PM
TAMR_GUS98
TAMR_GUS98's Avatar
Default Rear Spoiler.
Originally Posted by ULTiMaX99
^ yeah 3M take is incredibly strong. i used some to stick my hid ballast inside my fenders in my old car. when it was time to take em out 2 years later, i nearly ripped my fingers out trying to pry the ballast off from the fender. had to use a screwdriver and some wd-40 to get it off.
LOL. How did the fender look after? j/k
Btw, did you guys know that there is a template you can get from the dealer to drill the holes in the correct locations.
Here is what it looks like on the car prior to drilling.(any1 remember the blue tape)
Center punch all the markings on the template.
Drill
Line up the studs on the spoiler to the holes and bolt 'em up.
Done.
No need to fear drilling holes to do it right. No offense, but at work we have a name for people that install stuff half ***............................BUTCHER!!
Old 08-23-06, 12:14 AM
ULTiMaX99
ULTiMaX99's Avatar
it was actually inside the fender so you couldn't see the mess i left behind... it wasn't pretty hahah.
Old 08-23-06, 12:28 AM
TAMR_GUS98
TAMR_GUS98's Avatar
Default Pdr.
Then it's all good. As long as you don't have to do a Paintless Dent Repair from the outside. LOL.
-Will
Old 08-23-06, 07:15 AM
Flipsonic
Flipsonic's Avatar
Come to think of it, I was always behind you. I don't think you'll have too much problem passing me since you have 100 more horses under your hood.
Remember this.....
Quick Reply: Spoiler Installation Question
