View Poll Results: what should I do about the leather?
don't worry, it's normal
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
28
42.42%
take it back! that's messed up!
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
34
51.52%
other, (please specify in a post)
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
6.06%
Voters: 66. You may not vote on this poll
More leather troubles...
#31
2400 miles on my sterling perfed interior. Still looks brand new. Yours does indeed seem to be "messed up". Bad cow, HA. I don't think so. If they don't fix that somethings "messed up" with Lexus.
#32
That just show the seat are poorly designed and poor choice of material. I mean this sort of things would not happen to a BMW, MB or and Audi. Lexus had pick the leather and cushion simply too soft for daily use. It's a shame, really. It looks great and feels great initially but it doesn't last. My last car has momo leather and after 60,000km, it never showed any wrinkle and I've only used leather conditioner once a year and my car parked outdoors daily.
#33
I have the same problem...
leather strethches over time and it will end up looking like that..
but i realized it wore out realy quick, comepared to any other leathers seats ive seen. I think its cuz its realy loose.. not such a tight leather..
but i decided to live with it..
in 6month it will look like dat neways..
#34
Wow, nice to see everyone's input on this. I have a feeling i'm gonna get the raw end of this regardless how much I push for it. I'm gonna tell corporate (or the dealer, again) to show me any 06 IS (w/ perforated leather) with similar miles, and if any of them have a similar pattern, i'll gladly back off. However, I don't think they can produce a similar problem, ..in any of thier Lexus line, with even higher milage.
Greg
Greg
#35
Corporate really let me down. All they did was call the Service Advisor who first saw the problem an dasked him what he thought. ...well I could have told them that answer. I thought there would be some research or documentation involved. Now I go to another dealer for a second opinion.
Greg
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Greg
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
#37
my seat is doing something similar but instead of coming togeather in the center the right side center of the seat is roling over and is all loose its real crappy, my $29,000 A4 never had leather problems in 70,000 miles. and after 9,500 miles I have leather problems
#38
I've noticed something similar to the picture in the first post in this thread in my car as well. The odd thing is that it's not in the front seat where someone is always sitting. Rather, it's in the rear seat (both sides) where my kids sit when they're in the car - and that's only about 2 or 3 times a week. Neither one weighs over 60 lbs. My IS has only 7500 miles.
#39
UPDATE:
Sterling McCall Lexus came through for me. At least the first step of getting something done. The service manager agreed this was not normal. He's a leather specialist and said it was not the leather, but most likely the foam under it. He agreed there was no way this was caused by how I sit, nore was it any kind of wear. The protrusion is what caught his eye. So, ...I have a couple car shows coming up the next couple of weeks and must schedule an appointment after. Sometime in mid to late September I presume. They will peel off the leather to see what's going on, and if in fact it is "something", they will order such part(s) and hopefully remedy the situation.
Greg
Greg
#43
that car is also 4 years old!!! C'mon people, am I one of the only few with this defect?
FINALLY! someone esle has the same problem! ....just called my serrvice advisor and left a message. Let him know about this thread, and I was expecting a solution or i'd be calling corporate for resolution.
Thanks everyone for the responses.
Greg![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Greg
#44
I've seen people complain about minor wrinkles which makes me laugh, but I think your seat cover looks like it's stretched for some reason. It should not pucker like it is in the middle.
When I was having my 1966 mustang restored, I reupholstered the seats. I learned the hard way that to prevent puckering and folds, the material has to be pulled tight and then "hog-ringed" to the seat frame through the foam. If you don't have good tension or if the seat cover is not properly aligned, the seat will pucker or you will have folds. Also, if the seat foam is not the right thickness for the cover, you will also get folds (that should not be a problem with a new car). In my case, I had to redo my front seats and add an extra layer of padding (using padding similar to what that you would find in a quilted bedspread, not foam)--afterwards, they were as tight as a drum with no slack.
So I would go back to the dealer and complain, and if they object, then ask to see ten other IS's that are in for service to see if any of them have the same problem.
I'm not sure how this happened to your seat, but my IS seat does not look like yours.
#45
But they said the whole enchilada has to be replaced as a unit.
If they end up peeling yours off (successfully), please let us know, since I'd rather have them do that than replace a whole seat bottom.
