Spare tire compartment
I'm planning to get an extra stock rim/tire and replace the dummy one. I'm wondering whether the stock rim/tire will fit the compartment.
Also, are the rear rims a bit larger than the front?
As i know it fit the 16inch stock rim since the 16inch and 17inch IS has a 16inch stock rim for the spare... And 18inch will has a spacesaver for the spare...
Here's your opportunity to go outside and look at your tire sizes. You should note that the front tires are 225s and rears are 255s. This is a clue that the rear wheels are wider than the front wheels. This also makes it impossible to always have the right full size wheel and tire in your trunk in case of a flat, if it would even fit in the spare tire well. Which it won't.
Super Moderator
Also, the OEM 18" rim/tires are apprx 1" wider & taller b/w the front & rear.
on the IS250 AWD model here in US, all 4 tires are the same size and profile.
They are all P225/45/17
